Panasonic TX-L55DT50B
  • PontyPCs
    • May 2016
    • 15
    Hi Folks.
    Got This TV In A Boot Loop Panasonic TX-L55DT50B, Replaced The SPI Flash EEPROM Failed To Cure It, Does Anyone Have The NAND Dump File For This Please.
  • luis71
    PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
    by luis71
    Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
    I have backed up PQ,SPI,and Profile if anyone want
    Which usb_auto_update_??.txt can i use to dump firmware?
    I would be grateful if anyone could help me to find the firmware for USB recovery.
    11-05-2023, 06:31 AM
  • Takeatry
    Yet another Samsung QLED Boot Loop
    by Takeatry
    Samsung QLED QN50Q β€” purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
    10-04-2024, 02:57 PM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
  • zen
    Txl47e5b , panasonic nand chip advice
    by zen
    Hi all
    Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
    Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
    Managed to obtain a working main board , which has same software version .
    Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
    This proved NAND chip is the problem , in the form of corrupt data....
    02-02-2021, 11:51 AM
  • mijatovic86
    JVC LT-32VF52K - Boot Loop - Nand Flash Steps
    by mijatovic86
    I have an issue with JVC LT-32VF52K, that is chassis Vestel 17MB110.
    It just flashes Logo JVC and then red led flashes for 12-13 times.
    Tried with flashing SPI MX25L1606 but acts identically with it also.
    How can I try and flash the NAND using only USB ?
    Can it be done with USB flash drive and usb_auto_update_A1.txt file, and what should be the content of that file ?
    I did find a nand dump on elektroda.pl, just need to be sure how to flash it ? Its LED JVC LT-32VF52K_NAND.BIN around 540MB large
    11-11-2021, 04:20 PM
