SILO branded tv - model SL-4013 - no image, Nonbacklight, doesn’t always turn on
  • ngth82
    • Jul 2015
    • 541
    Has anyone ever worked on a “Silo” branded tv?
    I have one. Model SL-4013. The tv is in great physical shape.
    The tv only comes on very now and then. The backlights are good - I dismantled the tv and checked out the strings.
    The backlight circuit comes up to ~35V when it’s not working. It goes up to 75V to illuminate the strings when it works.
    The big cap stays at 165V in a working and broken state.
    The tv doesn’t always turn on either with the remote or the power button. The tv’s red standby LED doesn’t turn green.
    The SMPS, main and TCON are all integrated as a single board. As far as I see, the caps and diodes are good. There’s also little to no silk screen on the board to help with pin identification.
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
  • neilc6
    • Nov 2015
    • 1550
    Re: SILO branded tv - model SL-4013 - no image, Nonbacklight, doesn't always turn on
    Probably an eeprom issue. Actually a flash IC. 8 pin SOIC beside main procesdor. Try freezing it with an upside down can of duster before plugging in.
      • 12116
      • U.S.
      Hard to tell by the picture, is that a bad cap there by the plastic zip-tie holding those wires?
      • CapLeaker
        Leaking Member
        • 8115
        Heat up the caps on the main board a little bit with an hair dryer and see if the tv turns on every time. If it does, give it a full recap.
        • ngth82
          • Jul 2015
          • 541
          Thanks for the quick suggestions... Sorry for the poor lighting. I've left this TV in the garage - in quarantine if you will. I'll have some additional time to look at this tomorrow.
          The SOIC8 is a 25Q16BSIG - a quad SPI flash made by GigaDevice. I've run out of freeze spray and canned air. I'll have to source more cans. Good call.
          If we weren't locked down, i'd just remove the SPI flash and take it to work to read out the contents and verify the device integrity on the DediProg.
          Negative, the zip-tie area is a screw (please refer to the new pics here).
          I heated the board up earlier and it didn't do anything. I've removed all of the caps and tested each one with my capacitance meter. They appear to all be good.
          -Thomas
          • neilc6
            • Nov 2015
            • 1550
            I "repaired" the same device on a Proscan recently with intermittent turn on by erasing it and reprogramming it. Did order some replacements on Aliexpress in case the tv comes back but could take months to get in.
            I have a cheap ch341 usb programmer and a wide socket adapter. I read the IC after freezing and looked for some ascii copyright info in the bin file which is usually near the end of the data as a sanity check on the original bin.
            • CapLeaker
              Leaking Member
              • 8115
              next i'd do the eeprom.
              • ngth82
                • Jul 2015
                • 541
                I was going through junk boards and found a 25Q16CSIG. The "C" device datasheet says the programming time is faster than the "B" version that i have on the board.
                The other parameters and pinout appear to be the same from a quick glance.
                Also, I do have a Total Phase Aardvark that will read SPI devices. I just need to make an adapter board before i attempt to connect to it and read the contents out.
                -Thomas
                -Thomas
                • ngth82
                  • Jul 2015
                  • 541
                  Hi all -
                  Update - I was able to extract the SPI flash contents by wiring up my Aardvark SPI flash programmer to it. I dumped the contents twice and compared the binary contents with a diff tool. Looks the same.
                  As noted in Post #8, i found a 25Q16CSIG SPI flash from one of my junk boards. The "C" version is electrically equivalent, it just has faster timing so it should be a drop-in compatible.
                  I programmed the 25Q16CSIG. The programming verified as good (see screenshot and pics). I used an old T-CON with the same SMT pads and hooked up the MISO, MOSI, CLK and CS# lines to a header and provided power to the device.
                  I placed the 25Q16CSIG on to the Main board, but it doesn't do anything differently. It still takes multiple attempts at turning it on.
                  Any other ideas besides the EEPROM?
                  My compressed air cans are being delivered next week.
                  -Thomas
                  • ngth82
                    • Jul 2015
                    • 541
                    I guess my best option for a quick sanity check is to get a known good firmware image and a replacement SPI flash. SILO doesn't appear to provide one.
                    -Thomas
                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:20 PM
                    • 3D Modelka
                      AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                      by 3D Modelka
                      Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                      02-09-2024, 02:42 AM
                      HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                      09-06-2024, 10:56 AM
                      HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
