sony KDL-46W905A
  • mstv17
    • Feb 2020
    • wales
    sony KDL-46W905A
    Hi All this tv comes on with good sound and picture but goes off after 20 seconds with LED flashing 4 times I suspect main pcb, any other ideas would be great.
    Thanks Marcus.
  • neilc6
    • Nov 2015
    • 1550
    Re: sony KDL-46W905A
    Quick google search says 4 blinks is the backlight. Try turning down the backlight level and turn off any setting that may change the backlight level with ambient light.
    • neilc6
      • Nov 2015
      • 1550
      Service manual for KDL-40W900A found by googling. Should be similar. Most likely bad backlights.
      4X LED Driver Error [LD_ERR] (HG/TE Model) - Panel Module
      • mstv17
        • Feb 2020
        • wales
        Thanks for the reply neilc6 I will look in to the backlights further.
        Thanks Marcus.
        • stav242
          Sony KD-55X8509C white flashing/pulsing LED
          by stav242
          I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
          On inspection, there was no physical issues.
          I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
          - this seems to indicate repairing required, done by Firmware update.
          so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
          Inserted the drive and repowered the TV.
          LED changed to white flashing/pulsing ... and it sat there for over an hour.
          i was unsure what was happening so repowered the TV and now it just...
          01-08-2024, 07:39 AM
        • Richi777
          Sony KD-49x8505b flashing Red Led
          by Richi777
          Hello guys , i have one Sony kd-49x8505b with flashing Red Led anyone know common faults or this problem
          Thanks in advance...
          12-10-2024, 06:57 AM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
        • rabbituk
          Sony HCD BX7700dbi CMT flashing standby
          by rabbituk
          I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
          So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
          02-11-2025, 05:05 PM
        • D1964
          Sony KDL46w905A EMMC dump
          by D1964
          Hi Can anyone supply a EMMC dump for the above model please
          10-05-2025, 08:11 AM
