Re: Troubleshooting LG Plasma
Tested the Mosfets and the IGBTs that had short in circuit, and the Rectifiers as well.
Mosfets and IGBTs were tested in the same method, i.e. tested on and off state.
Rectifiers were tested like normal diodes, got 0.4 reading on the good ones.
Does this make sense? I also wonder if I should get the other 4 that are still on the board and test?
Why do I still have continuity on the IGBT / FETs / Rectifer connectors (holes) on the board even with the components out of the board (although not all of them have this)? I also noticed that 2 of the 3 holes of these components are covered in metal, the other is just a hole.Last edited by DanFen; 04-06-2020, 12:04 PM.Leave a comment:
I've ordered this diode, although I am not sure what else I can checkI haven't individually checked the rectifiers/fets I've removed though.
The problem is, the markings on it are so faint I can't read them.
EDIT: I think it says UF4007Leave a comment:
Did you lift one leg of the one with the bad reading too?Leave a comment:
You're correct, removed one of them and it measured correctly.
But the other didn't, there's continuity from negative to positive, and reading when set to to diode mode shows 0.002.
Now this is a funny one (or funny because I've never seen it), cause the Cathode side has a long leg which seems to be connected to some other component which I am not able to see (it's hidden under the heatsink). I'm attaching an image.
Unsolder 1 leg and test again. Capacitors can cause funky readings.Leave a comment:
Do the diodes have 3 legs? If so, the outer ones are connected and they will beep or read short. Test them center to an outer then center to the other outer.Leave a comment:
So I got all of those which I found were shorted out of the board. I must say that I never had such difficulty with desoldering components out like I had with these!
Some feet of these components have a round circle around them, what does it mean?
What is the best way to proceed from here?Leave a comment:
ThanksIs the testing of Mosfets and Rectifiers the same? Cause as you can see from the drawn diagram there is only one IGBT that is shorted, and from what I could find, these work a little bit different to Mosfets and Rectifiers.
The testing method is correct, if the IGBT measured shorted in circuit but looks good when out of circuit this means there is another IGBT or some other failed component.
Look at the traces to see what else could be the reason for the short.Leave a comment:
ThanksI'm attaching a diagram with those that are shorted (marked with a C). I couldn't successfully read the part numbers of some of them.
I've already removed the bad RJP63K2 and according to a previous post, it seems to be good. I did it like so:
Continuity between Drain & Source: no continuity (and I am guessing this is good?).
Then I've tested the On/Off state by charging the capacitor. I did this with the multi-meter by:
1. Holding the negative on the Source, and touching the Gate with the positive lead.
2. Then I moved the positive lead onto the Drain to test and got no connection.
Just want to make sure that the above testing method is correct for all the shorted components?
IGBTs might be connected in a parallel so you'd want to remove one by one and test out of circuit until you find that the board is no longer shorted.Leave a comment:
So I guess the next step is to remove all IGBTs/FETs that resulted as bad in the continuity test and test them individually?Leave a comment:
OK, so at least I'm on the right track. But this doesn't necessarily mean that the IGBT/FET is damaged right? Am I right to say that other components might be causing the short to ground on it? And if the answer to this is positive, that means that the IGBT/FET testing out of circuit might have good results... meaning, the IGBT/FET can be good?
Can do that, for the sake of learning
What I'm not sure about is, if I was testing them correctly while in circuit. I was setting the meter to continuity mode (beep mode) and alternating between all 3 pins. So S with G, S with D, and D with G, and see if it beeps. If it beeps I was noting it as short. Is this the right way or am I messing it up?
Thanks.
Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)Need some help please with a few components on this small board so that I can troubleshoot the circuit.
The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
J2 - to DC Output
J3 is Battery cell connector
however I am struggling to identify if:
Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....2 Photos -
I've been trying to figure this out for a while and am stumped. Help would be appreciated.
I have this ROG laptop that is not powering on and has no signs of life. I took it apart and started measuring finding no obvious shorts, all coils looked fine and input mosfets are reading good resistance.
I followed schematics I had found on the forum (linked below) and started following the power to the charge controller (PU8900, BQ24780SRUYT).
VCC - 19.65v
REGN - 6v
ACDET - 1.6v (this is what I believe is the problem)
ACOK - 0v... -
It has been a long while since I posted here to ask anything....hope you can help.
I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly... -
by phuzzydayFor masochists who want to see some of the crap that I have been through already... (Truly optional now though, all those trees were barked up for no reason.)
https://www.badcaps.net/forum/troubl...klight-circuit
I started a new thread to get a fresher look at things, even with eyes that looked before. It's different now!
So I got this on Facebook for $66US, blank screen. Just reseated all... -
by phuzzydayThis was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
(All the Electrolytics are brand new.)
I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out... - Loading...
