Element ELEFW401A No Power - suspected bad powersupply
  • Ifixstuff9
    • Jul 2017
    • 120
    I have an Element ELEFW401A that appears to be completely dead. No standby LED, no backlight, nothing.
    The power supply is a CVB42001 that was apparently used in a lot of cheap TVs a few years ago. I think its the issue with this TV because the the 12v rail going to the main board has no voltage. On the hot side I tested both main caps, 400v 68uF, and got 163v. On the cold side I got 0v on both capacitors. Any Ideas?
  • R_J
    • 9628
    Re: Element ELEFW401A No Power - suspected bad powersupply
    Using the negative side of one of the main caps (hot ground) check the voltage on the fet Drain (160VDC), and also the source(1~2vdc). then check if there is any VCC voltage (see picture) There are two small electrolytic caps (circled) they might be bad.
    • Ifixstuff9
      • Jul 2017
      • 120
      Checked the voltages, got the following:
      D - 165v
      G – 0v
      S – 0v
      VCC – 0v
      All of these were measured using hot ground
      • R_J
        • 9628
        Check the values of R5,R6 & R7, they feed a/c to ZD1 which is the startup voltage, check if ZD1 and R17, If ZD1 is shorted, R17 could be damaged. It looks like U1 is not providing the drive for the Q3 & Q4 which drive the mosfet
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          zd1 dont look too good on the pic .also q3
          • Ifixstuff9
            • Jul 2017
            • 120
            Thanks for the help everyone. I tested r5, r6, and r7 and they seemed to be all good at 357 KΩ. I also tested r17 which was good at 151 Ω.
            Do I need to remove zd1 from the board to test it properly? Because I got the same voltage drop when I tested it forward biased and reverse biased.
            I also checked C2 and C3 as suggested. I had to remove them from the board to get an accurate reading, but both caps tested good.
            • R_J
              • 9628
              If r17 is 151Ω, you should get a fairly good reading on zd1, There should be some voltage on C2, but it could be that U1 is bad and killing it, Can you make out the number/letters on U1?
              • Ifixstuff9
                • Jul 2017
                • 120
                All I can see on U1 is MUP CH ... not sure if that helps at all. Maybe tomorrow I can try again with a microscope but that chip is really small.
                • Ifixstuff9
                  • Jul 2017
                  • 120
                  Also I just measured C2 and C3 and got 0v on both.
                  • R_J
                    • 9628
                    A guess would be that it is a LD7535. Check the resistance across C2 (basically checking U1 VCC pin to hot ground) The ic likely has an internal zener that might be shorted.
                    • Ifixstuff9
                      • Jul 2017
                      • 120
                      The resistance across C2 is 10.4Ω
                      • R_J
                        • 9628
                        Check if D1 is shorted? Also there should be a diode connected across R19 and C12. It is likely mounted on the top side. It could be shorted. If the diodes are ok, it could be the ic bad
                        • R_J
                          • 9628
                          Did the markings look similar to this ic?
                          • Ifixstuff9
                            • Jul 2017
                            • 120
                            Yes the markings are similar. I tried to get a picture of the IC, you can just barely make out the text.
                            • Ifixstuff9
                              • Jul 2017
                              • 120
                              Ok something is definitely going on with that part of the circuit board. You were right about there being a diode across r19 and c12, its D3. I tried to test both D1 and D3 in circuit and both were shorted. However I then removed D3 from the board, tested it again, and it worked perfectly. I didn't remove D1 but it might be fine as well. So it seems that something is shorting that area. Its the same reason I had to de solder C2 to test it: when I tried to test it in circuit I got a short, but after removing it it tested fine.
                              Also I partially removed the heat sink on the hot side and uploaded a picture
                              • R_J
                                • 9628
                                I suspect the ic is bad, the important number is the P and the number above the CH, you may need to clean it with some alcohol But it does look like a LD75xx series
                                • Ifixstuff9
                                  • Jul 2017
                                  • 120
                                  Alright just checked the chip again, it says 36R above the CH.
                                  • R_J
                                    • 9628
                                    That would make it a LD7536R, I suspect it is bad, likely the internal vcc zener is bad. 10Ω is way too low for that pin.
                                    • Ifixstuff9
                                      • Jul 2017
                                      • 120
                                      Well I thought I'd update this thread in case anyone else has a similar problem with this TV.
                                      Anyway a new power supply fixed the TV. I was going to order a replacement LD7536R chip, but I couldn't find one in the US and I didn't want to wait a month for a part I wasn't 100% sure would fix the problem. I was able to buy a new power supply and main board for this TV on eBay for less than $20 shipped. I didn't need the mainboard, but it was cheaper to buy them together than to buy just a used power supply.
                                      Now, it turns out there are a few different versions of the CVB42001. One has two connectors for the backlight, the other has four. Other than this, the boards are the same. Because my TV had the two connector version and the replacement had 4 connectors, all I had to do is swap the connectors from the two board to the four board. I don't remember the exact process for this, but it was super easy to figure out, and works like a charm.
                                      • flysky
                                        Gigabyte H610M S2H V2 help to identify the element.
                                        by flysky
                                        There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                                        Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                                        01-23-2025, 07:21 PM
                                      • EasyGoing1
                                        The best way to drive a heating element?
                                        by EasyGoing1
                                        I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                        What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                        This is the general setup that I have now.
                                        This is what the...
                                        01-25-2023, 11:29 AM
                                        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                        by sam_sam_sam
                                        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                        12-16-2023, 08:39 PM
                                      • wwbielsko
                                        Macbook A1707 touchpad smd element identification
                                        by wwbielsko
                                        one sms element is missing at touchpad pcb in Macbook A1707
                                        Could anyone identify it ? Smd element is pointed on pictures
                                        thanks...
                                        01-09-2025, 01:10 PM
                                      • Capacitorial
                                        Powersupply has all the voltages - Monitor still no power
                                        by Capacitorial
                                        Hello guys,
                                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                        The weird thing is, that the Power LED is powered over the TCON board.
                                        On The TCON...
                                        12-28-2024, 02:12 PM
