Sony Bravia KD-65XE7096 with shorted power supply - SOLVED
  • R666
    • Jan 2020
    • 18
    • Spain
    Re: Sony Bravia KD-65XE7096 with shorted power supply
    Originally posted by R_J
    Does your led tester show the current each led string is drawing?
    Oh, yes. I forgot to mention. Each led string is drawing 122V.
    • R_J
      • Jun 2012
      • 9627
      The power supply does'nt show any damaged parts and there is voltage 97v
      going to the strings, So If I had to guess...
      It comes down to, is the main board sending the PWM etc. signals to the power supply. You could try heating the large ic under the heatsink on the main board, It could be a bad bga connection on the ic. Without being able to swap out the main or power supply It's hard to guess.
      • R666
        • Jan 2020
        • 18
        • Spain
        Hi everyone.
        I have some news about this problem. I've solved it by replacing the main board.
        Many thanks to everybody who helped me, specially @R_J and @budm.
        Can I ask the mods to change the title for this thread to "SOLVED: Sony Bravia KD-65XE7096 turns off with 2 blinks code"?. Also, since it's not a PS problem, this thread fits the most in the "Troubleshooting TVs and Video Sources" section.
        I'll try to fix the faulty main board, but I'll open a new thread for that.
        Thanxs again guys, you rock!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
