Bueller? anyone? anywhere?
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    Sorry but I have to ask again.
    ..1... Can a tv eeprom file be extracted from a firmware update.
    ..2... (Or does anyone know how the original eeprom chip was programed).
    ..3... Must a set be operational for a firmware update to be installed.
    ..4... Can the microprocessor be forced on.
    I have a Samsung un22f5000fxza with all proper voltages in standby but does not turn on. I believe the EEPROM is corrupt. I have the blank chips and programmer on hand but cannot find .bin file. This set has an external power adaptor with 14.9 volts. No power board in set.
    Thanks to all for being__WAR_KITTENS____!
  • NSkyLab
    Toshiba 55SL417U looking for EEPROM and Firmware
    by NSkyLab
    Hello everyone, I described the symptoms and measurements here
    It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
    I'm not able to find eeprom and firmware dumps in open sources.
    Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
    01-20-2023, 12:29 PM
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
  • dmccul2698
    Pioneer DEX-P99rs "No EEProm " diagnostic code.
    by dmccul2698
    Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
    1). Understand the schematic and check the connections between the EEProm and DSP
    2). Check the functionality of the EEProm
    I don't know if this is the unit's problem but it's a place to start.
    I have little to no electronic experience...
    04-08-2024, 05:32 PM
