LG 37LE5510 Sound gross distortion
  • dkneyle
    • Dec 2013
    • 441
    The sound output from DTV is white noise crackle with some barely audible audio behind it, which is grossly distorted. Sounds like an old vinyl record being played way too slow (best description I can give). I'm assuming something has gone wrong with the audio processor.
    I turned off all audio 'enhancement' features to eliminate that. Did a factory reset of audio settings. No difference.
    I ran the internal audio self test. Sound is PERFECT! (Not sure what the internal self check actually tests, but the problem is outside whatever it goes through.)
    I then subsequently played a video via the USB input and that sounded as it should, albeit out-of-sync with the videa, but that is not necessarily all that uncommon in my experience. 9Going to try the HDMI port to see what that goves me.)
    Haven't opened her up yet. No immediate clues from looking around the internet.
    Anyone had similar experience that can shed some light?
  • dkneyle
    • Dec 2013
    • 441
    Re: LG 37LE5510 Sound gross distortion
    HDMI port also has same defect. I'm obviously suspecting a mainboard fault, probably bad solder joints, most likely solder balls on main chip/s. I note this mainboard is mentioned in some posts for being notorious for failed solder ball arrays.
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • dreamlayers
      Weird clipping on Logitech Z-10 speakers
      by dreamlayers
      I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
      05-22-2025, 11:41 AM
    • LEECH666
      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
      by LEECH666
      Good day ladies and gentleman!
      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
      01-19-2024, 05:46 PM
    • Christos Tsiligiannis
      Marian Trace Alpha sound card repair help
      by Christos Tsiligiannis
      Hello to the forum.
      My name is Christos, I am new to the forum here and i am posting from Greece.
      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
      So i tried asking for a schematic from the company and they would not give me one. Instead they...
      11-18-2024, 05:26 AM
      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
      09-12-2024, 02:30 PM
