LG 60PM6700 Loud pop and now TV won't stay on
  • Stoodo
    • Apr 2017
    • 5
    LG 60PM6700 Loud pop and now TV won't stay on.
    When attempting to power on, tv will come off standby for 2 seconds then shut off again. TV will stay on if YSUS board is disconnected. (EAX64279701)
    Power board is EAY62609801.
    Should I assume YSUS board is defective?
  • Unspun01
    • Jun 2011
    • 349
    Re: LG 60PM6700 Loud pop and now TV won't stay on
    You are on the right track.
    If TV stays on when YSUS board is disconnected, the problem could be the YSUS or one of the Y-buffer boards connected to the YSUS.
    With all boards connected (including YSUS), try disconnecting the upper and lower buffer boards and turning on the TV. If the problem still remains after disconnecting both buffer boards, then the problem is certainly the YSUS.
    If the TV turns on and stays on with YSUS connected but upper and lower buffer boards disconnected, then the issue could be one of the Y buffer boards. You may then have to try with one buffer or the other connected to isolate which Y driver may be the issue.
    This may be one of the LG models that needs both working buffers connected to show an image. If one is not working, you will not get image.
    Without full circuit path, screen may only illuminate as dark grey for the half of the screen that is connected to a working buffer. Other half will remain completely dead.
    You can determine which buffer is the bad one by seeing if the upper or lower half of the screen dimly illuminates when only one buffer is connected when power is applied. (The connected buffer that allows screen to dimly illuminate is likely ok).
    • legg
      LG 42PC3 buffer output doesn't follow YSUS
      by legg
      LG42PC3D -UD originally with green lamp but no display or audio.
      Owner says was working, then went 'pop'.
      All 5V caps bulging. replaced.
      All PSU output voltages within spec but -Vy is low on YSUS.
      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
      eventually shorts DG. Replaced all 3 - -Vy now OK.
      Y scan buffer test point does not follow YSUS output below -50V
      Note: This unit seems to expect YSUS output to park at -Vy in between
      drive signal pattern periods. A replacement drive signal board confirms this....
      11-18-2021, 11:49 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • PlasMatt
      LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
      by PlasMatt
      I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
      09-20-2025, 06:50 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Yanleb
      Schematic or datasheet for Plasma TV buffer chip
      by Yanleb
      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
      05-18-2022, 01:36 PM
