LG TV 42LW4500 does not starts up LED red white red
  • mrobo
    • Nov 2006
    • 36
    • Bratislava
    Hi, my LG TV LG 42LW4500 stopped powering on one day, when I insert power cord cable to power socket the LED light turns on red color.
    When try to power on with remote it changes slowly from red to white (can hear clicking relay) and again slowly from white to red and TV stays off.
    Could you give me some suggestions where should I look for problem?
    I inspected the power board visual, looked for bad caps but found nothing.
    Thx for any help.
  • mrobo
    • Nov 2006
    • 36
    • Bratislava
    Re: LG TV 42LW4500 does not starts up LED red white red
    adding some pictures of the power board:
    • mrobo
      • Nov 2006
      • 36
      • Bratislava
      correct me please if I am wrong, is this the correct service manual for my tv?
        • 12331
        • U.S.
        #3 below is a good place to start, try to do it just as instructed.
          • 12331
          • U.S.
          Very good instructional video there: https://www.youtube.com/watch?v=ocqnqmBxiqY
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            The LW series LG TVs have a common problem with the BGA Chip. Try heating the BGA chip at 350F with a Hot Air Station for 10Mins.
            • mrobo
              • Nov 2006
              • 36
              • Bratislava
              from the lg service repair process I should go to A19 and A22, but
              can someone explain me the attachment
              how to do so?
              which is the IN-START button of the remote?
              • mrobo
                • Nov 2006
                • 36
                • Bratislava
                today I made some measurements and here are results, look attachment
                as you can see when I press power on on remote the votages on column pins2 - PWM jumps from 0,28V to 0,38V then (relay cycles) 0,01V again to 0,28V, any advice where should look next?
                • mrobo
                  • Nov 2006
                  • 36
                  • Bratislava
                  It seams that all voltages are correct only pin18 DRV-ON (Inverter On/Off) I have 0V, which voltage should it have?
                    • 12331
                    • U.S.
                    Suspect mainboard.
                    • R_J
                      • 9625
                      That is the control voltage which comes from the main board, likely 3.3 volts. It appears the main board is not sending the control signal, and likely the pwm control signal is also missing. Like others have said, likely main board fault
                      • mrobo
                        • Nov 2006
                        • 36
                        • Bratislava
                        Do you mean that voltage from pin2 PWM which jumps from 0,28V to 0,38V is low and should be 0 powered off and 3.5V when powered on?
                        Even the voltage pin18 DRV-ON (Inverter On/Off) on which I have 0V, should have 3.5V when turned on TV?
                          • 12331
                          • U.S.
                          Yep, 0 volts DRV-ON means no backlights.
                          • R_J
                            • 9625
                            The PWM pin is "Pulse-Width Modulation", you would need a scope to look at the waveform.
                            DRV-ON needs to be high(3.3v) to turn on the backlight, but you can't force it on with the main board connected as you could damage the main board.
                            Look at the main board and see if you can find Q405. This is the inverter control transistor, It might be shorted. The INV_CTL signal comes from IC1002 (microprocessor) and drives Q405 base
                            • mrobo
                              • Nov 2006
                              • 36
                              • Bratislava
                              Today I found the NPN transistor Q405 2SC3052 and measured it on board like diodes with digital multimeter and here are results:
                              -pin1 Base to +pin2 Emitter = 1969 mV
                              -pin1 Base to +pin3 Collector = infinity
                              -pin2 Emitter to +pin3 Collector = 965 mV
                              reverse measurement:
                              +pin1 Base to -pin2 Emitter = 627mV
                              +pin1 Base to -pin3 Collector = 624 mV
                              +pin2 Emitter to -pin3 Collector = 724mV
                              for me it does not look like shorted, but not sure if it is good or bad, any next idea? advice?
                              • WhiteWolfHellas
                                • Jun 2019
                                • 95
                                • Greece
                                I have a 42LW5400 which doesn't turn on and has the led pulsing red. I tried heating the mainboard but nothing changed.
                                • mrobo
                                  • Nov 2006
                                  • 36
                                  • Bratislava
                                  +pin1 Base to -pin2 Emitter = 627 mV
                                  +pin2 Emitter to -pin3 Collector = 724 mV
                                  compared measurements on Q401 same transistor type
                                  -pin1 Base to +pin2 Emitter = infinity
                                  -pin1 Base to +pin3 Collector = 1963 mV
                                  -pin2 Emitter to +pin3 Collector = 1521 mV
                                  +pin1 Base to -pin2 Emitter = 628mV
                                  +pin1 Base to -pin3 Collector = 631 mV
                                  +pin2 Emitter to -pin3 Collector = infinity
                                  • mrobo
                                    • Nov 2006
                                    • 36
                                    • Bratislava
                                    does the relay clicks when powered on with remote, then you have probably same problem like me
                                      MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 07:46 AM
                                      MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      09-06-2024, 07:29 AM
                                      MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 07:25 AM
                                      MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                      This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
