Re: Samsung UN55D6005SF
Ok so we at least know that voltage is correct. Which voltages am I missing here?
Samsung UN55D6005SF
Thank you for explaining that! I never understood how that worked but it makes sense now. Much appreciated.The BL-ON pin on the power supply board has pull-up resistors for performing power supply board self test, when the power supply board is connected to the main board, the main board will keep the BL-ON line low (<1V), when the TV is turned on then the main board allow the BL-ON to high turn on the backlights circuits.
So at this point you have more than just BL-ON problem on the main board some where. If you check the Voltages at the power supply connectors you will find that some other control Voltages are not there either.
Does the PSON voltage need to be in the 5v range as well?Leave a comment:
So at this point you have more than just BL-ON problem on the main board some where. If you check the Voltages at the power supply connectors you will find that some other control Voltages are not there either.Leave a comment:
The only way I can keep the backlights on is if the mainboard is disconnected from the power board.Try having just the BL-ON wire disconnected and everything are back in place so you will get backlights, and if there is no other problem any where else then you should see image and sound and all other functions of the TV, if not then you have more than just no BL-ON signal.Leave a comment:
Ok so BL-ON disconnected and everything back into place when i power on the TV it flashes the splash screen and turns off.Try having just the BL-ON wire disconnected and everything are back in place so you will get backlights, and if there is no other problem any where else then you should see image and sound and all other functions of the TV, if not then you have more than just no BL-ON signal.
so no change on that...
I must ask though if BL-ON is already at a voltage of 0 why would disconnecting it make any difference?Last edited by bleed4me; 11-11-2019, 01:50 PM.Leave a comment:
Anybody have some insight on how to trouble shoot the mainboard to fix BLU_ON signal?
Just a thought but could one simply find another 5v triggered pin and jump it?Leave a comment:
It's looking more like you have a mainboard fault with the BLU_ON signal not being activated.Leave a comment:
The only time the backlights will stay on as well as the tv is if the mainboard is disconnected from the power board. All the other options i have tried just makes the tv power down.Leave a comment:
Correct if you disconnect the mainboard from the power supply the backlights do com on and stay on.Leave a comment:
Sorry I was at work. So I retested everything just to make sure and here are the results...
If I disconnect the mainboard the tv will stay on and the backlight is on.
If I disconnect the tcon board from the mainboard the tv will flash ( no spash logo ) and shut down.
If I disconnect one of the tabs on the tcon board that go to the panel when i power it on I get half the screen with the splash logo and the other side is white but has like a green ghosting that fades and turns off. If I test the other tab I get the same results just on the other side.
All of these were tested one by one.Attached Filesif you find these attachements useful please consider making a small donation to the site
can you clarify... you are doing one cable at a time NOT completely disconnecting all the tcon to panel cables at the same time... right? The screen should show up white on the disconnected side "normally".Leave a comment:
So with the Tcon disconnected the set stays powered up?. Can you post a photo of the Tcon?Last edited by dick_barton; 11-05-2019, 08:53 AM.Leave a comment:
If I disconnect the tcon board the tv will power on but with no Samsung splash and stay on.Leave a comment:
since you get backlights on with the main board disconnected, that indicates the problem is either with the main board or something it "sees" isn't good and as a result, after the "flash and splash" then shutdown. You can try unplugging, one at a time, the tcon to panel cables to see if this changes the result. This may check whether the issue is with the panel and / tcon depending and what the outcome is. Of course, do the cable disconnecting / reconnecting with the power off. :-)Leave a comment:
It looks like the mainboard isn't sending the BLU-ON signal to the powerboard.Last edited by nomoresonys; 11-05-2019, 04:12 AM.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
