Hi Guys,
I know there are some other threads, but it seems the faults are little different, that is why I opened another thread, hope that was ok!
I have a little problem with my LG 55EC930V TV Set. I bought it on ebay for 80 Euro. The relay inside the TV will klick, logo on the bottom will be lid and after ~3 seconds I hear another klick and logo fades out.
I checked the PSU and when using both jumpers, 3,5V to DRV-On and PWR-ON, all voltages are ok and in range.
Then I tried to set the PWR-ON jumper (DRV-ON was set all time) while all boards and cables were connected and I got the automatic test pattern from the TV, switching from white to black, red, blue and green. I took a video and here are some pictures from it. So I thought, the panel is fine and used the power only mode and again, I got a white screen with the power only box showing but shortly after I left the power only mode, the TV somehow crashed, right side went dark and shortly after that the whole screen was showing horizontal lines black and white line. (pictures attached)
From time to time I am able to reproduce this, but most of the time it will hang within the first second when showing the test sequence, mainly green or blue with black stripes. Power only mode also doesn't work anymore.
Yesterday I received 2 other used T-Con boards but same result. Without the DRV-ON jumper nothing happens, with the jumper the same fault as mentioned before, as you can see on the attached failure picture.
Any ideas? Is my panel broken even though it seems to be fine from time to time?
Is it the Mainbaord? Should I try to get a replacement?
I was thinking to remove R11408 (0 Ohm) of the Burnt detection signal on the mainboard to see how the TV will behave?! Any thoughts about that?
BTW All fuses and cables are checked several times and no burnt smell nor component were seen on any of the boards.
I have Mainbaord Version 1.1 (without LED and micro switches).
Any help is appreciated!
