Hello I have a Panasonic TCP42ST30 that has 6 Blinks. The SC Board is a TNPA5349 (SC + Buffer Board Combo). The TV was brought to me with a SOLID (No Blinks) red light when the power was pressed. I decided to open up the TV and the SC Board (SN2) was short to ground 0.3 Olms with Fluke Meter. I replaced 3 out of the 6 of the MOSFET 30F131 which was short. All the other typical MOSFET was good such as DG302. After the replacement the SN2 now has 155K Olms. I plugged it in the TV shuts down after on for 1second. I can see the brightness during that 1 second. After shutting down, the TV flashes 6 times. Any tips?
TCP42ST30 6 Blinks
Re: TCP42ST30 6 Blinks
The following repair kits provide the following in their kit
https://www.ebay.co.uk/itm/151128828955
PARTS Q401 Q402 Q421 Q422 Q441 D401 D421
PLUS IC502 AND Q531 WILL FAIL IN 20% OF CASESLast edited by dick_barton; 10-24-2019, 07:53 AM.Willing to help but I'm no expert.
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
...1 Photo11-20-2024, 08:52 PM -
by Taurus12Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
Any recommendation on what I have to do next? Thanks in advance -
by jchonHi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
I found the service manual, which was critical to know where to probe.
https://www.manualslib.com/manual/20...1e-Series.html
With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
Unfortunately the 5-blinks... - Loading...
