RCA RLDED3955 39" LCD - Backlight Flashing
  • itachi
    • Mar 2018
    • 27
    I have a TV here that when powered up, the backlight blinks between dim and normal brightness over and over.
    I started troubleshooting and found that the main processor on the board was sending a signal to turn the LED driver OB3350 on over and over, like it was trying to start it up but failing. On the schematic that's coming from ASIC_PINx.
    I bypassed this signal and forced the LED driver IC high which still resulted in the backlight flashing brighter. I spent some time probing things and found that there was a constant 3.2V being applied to the PWM pin of the LED driver, and traced that back to the main processor. Now the OB3350 datasheet mentions that:
    "OB3350 is enabled by applying a voltage of greater than approximately 2.5V to PWM pin."
    So 3.2V appearing on this pin sounds correct. But to test it further I decided to feed a 0-5V PWM signal into this pin and found that the backlight's brightness corresponded perfectly to the duty cycle. It seemed to work fine.
    My theory is that the main processor on the board is perhaps looking for an active High/Low signal on one of its pins when the LED driver is activated but never sees it. It just keeps trying to turn it on, and the PWM signal is locked to ~3.2V as if its stuck in an initialization mode.
    At this point I could just set the brightness to a fixed value with some resistors and leave it but now it's starting to bug me.
    Here's an approximate schematic of the LED driver:
  • neilc6
    • Nov 2015
    • 1550
    Re: RCA RLDED3955 39" LCD - Backlight Flashing
    Backlights flashing is bad leds in the backlight. Always suspect bad leds if the backlight flashes, flickers, or doesnt come on before suspecting other boards. If you repair it, you can turn down the backlight in the service menu under panel settings to about 55. With tv on, menu-1-1-4-7
    First tv i attempted a backlight repair on and ended up cracking the panel.
    https://www.badcaps.net/forum/showthread.php?t=59882
    • itachi
      • Mar 2018
      • 27
      Thanks for the input, you must be right because its acting pretty weird no matter what I do. The screen appears evenly lit for the most part but there's probably an LED out in there somewhere.
        What happen if you turn the backlights level down to 50% in the service menu?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Probably that RCA TV can't adjust backlights.
