Lg 60pz570 No picture, No sound, No Z-Y voltages
  • MerlijnD
    • Aug 2019
    • 6
    • Nederland
    Hi people,
    Got my hands on a sweet 60 inch plasma. Guy i bought it from showed me live at his house: Turn on, relay clicks, faint glow until you turn it off.
    So I went online, searched and found around the same model and people saying cracked solder etc, fused. So I wasn't smart and just took the boards apart as im a "electronics hobbyist". Indeed 1 or 2 cracked solder points. Fets measured OK from a quick check on my end, so did the fuses.
    Resoldered the points, replaced one "starting to bulge" capacitor, and put the things back in. But now it does nothing anymore. As in: Turn on, relay clicks but no faint glow anymore. Just black screen.
    Baseline:
    Zsus
    Incoming:
    All in spec
    Outgoing:
    VZB: 0.9v
    Ysus
    Incoming:
    All in spec
    Outgoing:
    VY: 0v
    VSC: 0v
    When disconnecting Ysus board power ZSUS VZB 0V.
    When disconnecting ZSUS board power Ysus both test points still 0v.
    Led on logic board blinks Long-Long-Short-Pause-Short
    Not quite sure how sensitive these boards are, but incoming 5v = 5.16v. Not sure if thats within spec.
    Disconnecting LVDS and jumping ext_auto_gen:
    Zsus
    Incoming:
    All in spec
    Outgoing:
    VZB: 5-9V
    Ysus
    Incoming:
    All in spec
    Outgoing:
    VY: 5V
    VSC: 5V
    Nothing on screen. Faint coilwhine from ZSUS board, double powercycle on ZSUS board (10 seconds in between, 2 seconds slight coil whine per cycle), Tv turns off after that.
    I have literally no idea what's wrong, yes it was stupid to not test the voltages when it still had the dim glow, but instead i fixed the solder cracks first. Anybody know whats going on?
    Greetings,
    Merlijn
  • R_J
    • 9555
    Re: Lg 60pz570 No picture, No sound, No Z-Y voltages
    Start by rechecking every connection you soldered, you may have shorted a couple connections together. Post some pictures of the y-sus and otherboards you worked on.
    • MerlijnD
      • Aug 2019
      • 6
      • Nederland
      Hi, I've rechecked everything and i am 100% certain all is good. No solder blobs, in EXT-AUTO_GEN mode it sounds like the ZSUS board wants to start (9V coming out) or something but the YSUS board seems completely dead (2V coming out).
      All of the SMPS voltages are bang on (except the 5v (5.16v)) with the label on the back.
      Reseated connects, and measured buffer boards. Found no direct shorts to ground.
      Pictures attached.
      • MerlijnD
        • Aug 2019
        • 6
        • Nederland
        Small update, I mucked around with my hairdryer. Warmed up the ZSUS and Control board. Behavior changes a bit, relais in SMPS got a bit spastic and i got 55V on the ZSUS board for a brief moment.
        18v control is present on YSUS board 1-2 seconds after startup. Then its gone again (so is the static noise/coil whine).
        • MerlijnD
          • Aug 2019
          • 6
          • Nederland
          Well it wasnt the logic board, replaced that. Same issue, same blinks.
          Disconnecting 1 or the other buffer board didn't make any difference.
          • MerlijnD
            • Aug 2019
            • 6
            • Nederland
            Well I measured the 18v control signal on the ZSUS board, measurus 4.5v.
            The 15v outgoing rails from the YSUS (guess this is boosted to 18v normally?) is dead, same 4,5v.
            Now I don't know when these voltages should be there, if they should be there during startup or if they are controlled by the logic board.
            From reading other threads regarding the missing 18v, i've seen people talk about the voltage regulator, sadly this is on the back of the board for me, so I can't measure it while on.
            Does anyone know if it's worth it to blindly replace the 200D6 pwm switching controller IC, or am I looking at the wrong IC here?
            Looked at this thread: https://www.badcaps.net/forum/showpo...9&postcount=18
            • Capacitorial
              Powersupply has all the voltages - Monitor still no power
              by Capacitorial
              Hello guys,
              I have a Philips 240B7QPJEB. The monitor seems completely dead.
              I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
              On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
              The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
              The weird thing is, that the Power LED is powered over the TCON board.
              On The TCON...
              12-28-2024, 02:12 PM
            • gjgib
              Help reading schematic voltages input/output
              by gjgib
              Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
              I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
              I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
              I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
              05-06-2024, 08:11 PM
            • RossMoodley1967
              HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
              by RossMoodley1967
              Hello
              Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
              Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
              03-01-2024, 06:07 AM
            • karlp028
              MSI Z390-A PRO missing VCORE voltages
              by karlp028
              I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
              06-23-2025, 01:25 AM
            • lol999
              Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
              by lol999
              Motherboard after starting show Q code 00.
              No shorts on any rail ( at last I can't finde any)
              All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
              Nothing get hot, PSU starting, all lights came ON....
              One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
              After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
              This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
              01-21-2024, 02:25 PM
