GoodMans G50238T2SMART /CPT07 15
  • eyesociety
    • May 2015
    • 8
    Does anyone have a schematic for this TV.
    The power supply model is PSU:CV55001A-006
    I know that I have posted this before but being pushed for the repair.
    https://www.badcaps.net/forum/showthread.php?t=78330
  • eyesociety
    GoodMans TV
    by eyesociety
    Hi all.
    I have receved a 50 inch led tv model G50238T2SMART /CPT07 15
    No power from PSU:CV55001A-006
    Does anyone have a Schematic diagram for ths TV
    Thanks in Advance.
    Dave....
    08-03-2019, 01:59 PM
  • chopper00
    Goodmans G58ANSMT half the picture slow to refresh
    by chopper00
    Anybody have any ideas why half the picture would be slow to refresh?
    02-12-2022, 11:05 AM
  • TimeRabbit07
    Asus FX517ZC charges but power button does nothing
    by TimeRabbit07
    Hi all!
    I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
    Here are its various numbers and identifiers:
    Model short: FX517Z
    Model long: FX517ZC-HN114W
    SN: NANRCX01S57842E
    CN: 3SDB 12M
    MFD: 2022-10
    Motherboard model: DA0NJLMBAE0 REV E
    Symptoms:
    The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
    History so far:
    The...
    09-04-2024, 05:48 PM
  • air_chair256
    Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
    by air_chair256
    I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
    Tried to reball RAM 1,2,3,4
    Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
    02-13-2024, 06:00 AM
  • sansonet
    Diode ID (Food Processor Switch)
    by sansonet
    I have a small food processor with two speeds, but it doesn’t handle long use very well and tends to overheat. I guess I pushed it a bit too far this time because it started smoking. After letting it cool down, I tried using it again, but only the second speed is working. The motor seems fine, but I really want both speeds to work. When I opened up the switch cover, I found a component that was completely burned out—probably a diode. I want to replace it, but I'm not sure what type I need. It’s next to the switch that’s still working, but the one on the left for speed "I" isn't...
    10-15-2025, 11:18 PM
