Repair LG 60UF770V
  • jay459
    replied
    Re: Repair LG 60UF770V
    New main board coming today I hope. £70. Not too bad.
    If a new main board doesn't fix it, I've no idea what to do.
    Is it possible a faulty tcon board could cause issue in picture at start of post
    replied
    Might find a replacement board on that page but who knows if it will have the same problem in the near future: https://www.ebay.com/sch/i.html?_fro...&_odkw=fire+tv
    replied
    Send it off for reballing, should be much cheaper than finding a replacement board.
  • diif
    replied
    Originally posted by aidy55
    You mean this chip here. Yea looks difficult. I can see what I can do with my heat gun.
    Ready to give up on this TV. Its up in the attic now out of the way, will have to make do with a 42 inch on the wall.
    Maybe will find someone who has smashed screen, spares and repair.
    Does anyone know of any centres that may deal with large number of broken TV. Basically a scrappy for tvs lol
    There are a few in the UK, EMOS, spares2repairs and tvparts spring to mind.
    Good luck with finding one though, BGA failure on the LGs is common so they are rare. You might get lucky on ebay but most people seem to ask silly money for broken screen TVs, although you do occasionally find them cheap.
    You ideally need more than a hot air station to effectively reflow the solder. The heat has to be even and you don't want just the processor area heating up, the whole board should be around 150c to avoid thermal stress before reworking it.
  • aidy55
    replied
  • aidy55
    replied
    Lg won't provide schematics
  • aidy55
    replied
    Where can I get schematics for main board, if I ring LG will they provide them.
    OK ill get the heatsink off and have a look at IC, I've got fine solder tips and hot air gun from my solder Station so will give it a go
  • Sevenqi
    replied
    You need to remove the white mental heatsink and you'll see an IC.
    Rework means re-soldering that IC, but it's BGA IC so it's a bit harder and skillful. Please refer to youtube video for BGA soldering tips if you're not experienced.
  • aidy55
    replied
    Not sure what you mean to rework IC under white heat sink. Here is a picture. Where should I heat it, I've got a hot air gun on my aoyue solder Station.
    I've spotted a few solder points that look like they need touching uo
  • aidy55
    replied
    I've replaced the power board, no difference. Replaced one of the lvds cables, they are not the same, they are different sizes so could only try on. But I don't think its that anyway. Going to return these parts.
    I can get a t con board on ebay but not sure what that could do
    A computer repair shop nearby does bga rework, might try them.
    But the TV is not booting up at all. When you press the power button the TV does light up but just black screen but it is even back-light if you know what I mean, so it couldn't be display
    Still can't find anything solid on why standby light blinks twice
  • aidy55
    replied
    Will try all these tips.
    I think I will replace power board as well since I can get one for £20.
    Maybe it will allow the tv to turn on again
    Is it possible to test mainboard, is there schematics available to check readings with multimeter
    replied
    https://www.youtube.com/watch?v=ZDQNOU2w_ek
  • diif
    replied
    There isn't a main board available anywhere. Lg quoted me 400 quid can you believe
    I've got a decent soldering station with hot air gun. I've used the hot air to solder smd leds but never rework components.
    What temp should I be hitting it with
    Also my TV doesn't turn on at all ow, standby just blinks a couple of times. I can get a power board for 20 quid
    There is a reason BGA rework stations are a thing, they preheat the entire board and give a fairly accurate way to follow the reflow temperature profile evenly over the entire processor.
    With the board being £400 and as rare as unicorns second hand, perhaps consider getting a professional to reball your board.
  • aidy55
    replied
  • Sevenqi
    replied
    Try to rework the IC under the big white heatsink, the UF series has the same common issues, or replace the main board.
  • diif
    replied
    LG told me to ring Very. Very told me to ring LG. Both not interested. Complained as much as I could. Purchase price was £1099. Tv 2.5 years old. 1 year warranty.
    LG said new main board £400.
    I've got this lvds cable through, Is it worth replacing?
    Of course Very won't be interested, they are responsible in this case.
    A complaint in writing, reminding them of consumer law in this country ?
    If you've given up making a claim, I'd ring around first. Some TV repair places just replace boards, others do BGA rework.
  • aidy55
    replied
    Is it worth leaving in to a TV repair shop. If it is the main board will they be able to repair it without replacing
  • Wilderone
    replied
    Are you saying I need to swap these wide ribbon cables going down. I thought they were for speakers.
    Doest look like they can be swapped over
    Yes those wide ones, there will be clips on both panel side & Tcon side.
  • aidy55
    replied
  • aidy55
    replied
    I’ve got this lvds cable through, Is it worth replacing?
    Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) L Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 04:30 AM
    Lenovo ThinkPad L13 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad L13 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 + 3YOS Warranty boardview and L13 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
