need insignia ns-39l240a13 eeprom!!!
  • Amper Men
    • Mar 2018
    • 7
    • mexico
    insignia ns-39l240a13 main part # 569mf1101a (6mf01001b0)
  • VladC
    retired EE
    • Jan 2014
    • 7
    Re: need insignia eeprom!!!
    Did you get that?
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • vbogoev
      Lenovo S6000 won't turn on. Data recovery needed.
      by vbogoev
      Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
      Code:
      [PWRAP] pwrap_init_preloader
      [PWRAP] pwrap_init
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
      [PMIC_WRAP]wrap_init pass,the return
      06-20-2023, 06:36 AM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
