Panasonic plasma TX-P50GT60 , blinking 6 times.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hi guys ,
    It's been a while since i repaired a tv. The Panasonic's are getting rare....
    Picked up a defective GT60 that was completely dead. There was no 5v standby at P6 so i knew it was a bad powersupply. ( 5v should go to the mainboard , mainboard turns on 15v etc ).
    Replaced that because the previous owner soldered on area's that made absolutely no sense at all so i couldnt bother repairing the board.
    After replacing the powerboard i got 7 blinks which pointed me in the scboard/bufferboard area. Checked the buffers and they are fine.
    So this brings me to the scboard and i found 4 shorted 30F132/RJP30H2A.
    I replaced those 4 and now the tv is blinking 6 times which means the Driver SOS1 (SC Energy recovery circuit) (A-SC FPC DET) has a problem. The green led wont light up and i cant find any other shorts.
    Can someone help me a bit? This is probably the same fault as on the 30 series with the 8 legged IC. ( IC501 ).
    I could replace the scboard and sell the tv but this is more fun.
    The service manual is attached and the scboard is on page 39. Im suspecting IC16522 and/or Q16452 because they are in the recovery area.
    Thanks guys!
  • Cooperman87
    • Aug 2019
    • United Kingdom
    Re: Panasonic plasma TX-P50GT60 , blinking 6 times.
    Did you manage to solve the issue? or did you just replace the SC board.
    I have the same model, used a SC jig to seperate the fault from the SU/SD boards.
    Any information would be great.
    • ahmarzo
      Hp 15-cs laptop 5 times dc jack blinking white
      by ahmarzo
      I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
      First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
      Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
      But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
      12-28-2024, 04:46 AM
    • YasaCh
      Sony kdl 40p5500 red light keeps blinking 3 times
      by YasaCh
      Hello...
      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
      i opened the back cover no sign of damage on the powery suply or motherboard
      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
      07-07-2025, 11:53 AM
    • fourroses73
      Panasonic Plasma TX-P46VT20 blinks 10 Times
      by fourroses73
      Hi all folks.
      My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
      Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
      What i have measured:
      Vsus and Vda are ok
      Pin1 of connector P7 : 5V ok
      Pin1 and 9 of connector P6: 16V in place of 15V but...
      12-03-2020, 05:28 PM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
