LG 42Pj350 ysus maldischarge
  • Farasa
    • Jul 2016
    • 47
    • South-Africa
    Need assistance please
    I recently got in Lg 42pj350 with the usual y-sus problem,found four Igbts shorted 30f124 & 30J124 repalaced those refreshed the board then I examined the Z-sus board,to find the coil had dry joints..re-soldered most of that board...it came on nice,tested it for couple of hours
    I released it to the client,it came back five days later,I found all the Igbts I replaced before shorted with the addition of two fets...I replaced all these checked the board again,replaced it...now I have mal discharge ...what else can I do thanks in advance
  • Farasa
    • Jul 2016
    • 47
    • South-Africa
    Re: LG 42Pj350 ysus maldischarge
    Quick I re-checked the y-sus again....I replaced the driver 7371...ic703...maldischarge gone...now I'm testing the heat of the fets..to make sure its not heating too quick ...then I will release it,and pray it stays out
    • Farasa
      • Jul 2016
      • 47
      • South-Africa
      Update on the set...still working however I got another one..came in with maldischarge red snow ..I hope to replace driver 73711
      • PlasMatt
        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
        by PlasMatt
        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
        09-20-2025, 06:50 PM
      • Salvatore057
        plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
        by Salvatore057
        I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
        Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
        I am lost, should I change the YSUS board? Is the YSUS board damaging...
        04-29-2018, 01:29 PM
      • legg
        LG 42PC3 buffer output doesn't follow YSUS
        by legg
        LG42PC3D -UD originally with green lamp but no display or audio.
        Owner says was working, then went 'pop'.
        All 5V caps bulging. replaced.
        All PSU output voltages within spec but -Vy is low on YSUS.
        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
        eventually shorts DG. Replaced all 3 - -Vy now OK.
        Y scan buffer test point does not follow YSUS output below -50V
        Note: This unit seems to expect YSUS output to park at -Vy in between
        drive signal pattern periods. A replacement drive signal board confirms this....
        11-18-2021, 11:49 AM
      • Truncatedhose
        Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
        by Truncatedhose
        Greetings all!
        Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
        Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
        07-04-2018, 10:59 AM
      • zwarder
        eax61319402 50PJ350 YSUS
        by zwarder
        Hi
        Had shorted YSUS
        Q24 RPJ63F3
        C726 cap
        Q11 K3667
        R528 & R529 2.2 ohm
        replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
        ZSUS is also good as far as I can tell
        Anyone could help me out on this one
        10-23-2023, 08:11 AM
