50PB560B -LG common problems?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #41
    Re: 50PB560B -LG common problems?
    That seems awful low but I'm unfamiliar with the layout of this buffer. Normally it is measured across a resistor.
    Perhaps someone else could offer advice here.
    The only other thing is to try and get the set two switch on again and then measure +Vsc once again.
    The white label on the back of the panel can you post a picture of it because it does give information.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      Just seen this in another post relating to this model. To run the self test successfully
      Originally Posted by tvtimmy View Post
      Unplug the ldvs cable(flat one) that runs from the Main board to the control board and put a piece of wire in the holes on control board marked r451 and r452. If you have test patterns and colored screens your main board is bad.
      Hi, did what you suggested, and still wouldnt turn on, so unplugged the cable from PSU to main board, and it turned on, then did what you said and got test patterns
      • jp_fizzer
        • May 2020
        • 17
        • Saudi Arabia
        #43
        Ok, I tried what the other poster did. I unplugged both the ribbon cable between control board and main board as well as the cable between power supply board and main board, inserted the jumper and plugged in TV. Nothing happened.
        Then I connected everything back up again and the TV turned on. Since it was powered up I retested the voltages on the Y buffer board. The Vy is still 190V but the Vsc is very strange. When I put red probe on Vsc and black on chassis the meter just bounces on DC setting so I tried switching to AC and it is pretty steady around 120VAC, which is the line voltage I am plugged into. I switched back to DC and reversed the probes so black on Vsc and red on chassis, it is bouncing around 6-8 VDC.
        Edit: I re-tested Vsc, this time using my Fluke T5 which has voltage autoselection and it is giving me 113VAC, so definitely it is thinking it is AC basically line voltage. This is while the TV is working.
        • jp_fizzer
          • May 2020
          • 17
          • Saudi Arabia
          #44
          Here is the white label
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            All your voltages appear to be good other than Vsc whcih I'm unsure how or where you measure it. Hopefully someone else can provide an answer.
            The other person did get the test pattern to run so I'm suspicious of your logic board.
            At this point I am out of any further ideas but hope you get some more help from other forum users.
            • jp_fizzer
              • May 2020
              • 17
              • Saudi Arabia
              #46
              Here is where I am measuring Vsc on the Y buffer board. You can see from the picture that I get -23VDC when the TV is powered up but not working and I get 113VAC when the TV is working. Now the 113VAC does not seem to be related to the line voltage because I have tried it plugged into both 110V mains and 220V mains and this Vsc voltage reads the same.
              Does this Vsc voltage provide any clues about what could be the problem?
              Any suggestion what to test next? I have left the TV on in case there are any tests while it is on. As soon as I turn it off it will take many tries to get it to come back on again.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #47
                If the set powers up and all the voltages appear to be correct and if we ignore Vsc for a moment, what you do know is that the set will not go into self-test mode, then perhaps there's a problem with the Logic board.
                • jp_fizzer
                  • May 2020
                  • 17
                  • Saudi Arabia
                  #48
                  Is there any known way to test the logic board? It looks like I could buy one for around $50 with shipping but it would be kind of nice to confirm that it was the problem before spending this.
                  • Rene77
                    GTX 680 problems, Wrecks main board
                    by Rene77
                    i tested this Asus gtx 680 which came with a bunch of computer stuff.
                    When i only connected the 8 pin, the PC still started and gave the error on the display that also the 6 pin needed power.
                    when all connectors where powered and both leds were green, the PC did not boot, Fans where running, but nothing else.
                    Even when removing the GTX this failure kept on the main board.
                    No boot, no beeps, only the fans running, nothing else.
                    main board was a Asus B85m-G, PSU 650 Watt.
                    Tried a second (old) main board with a dual core, same...
                    12-29-2022, 02:18 AM
                  • cmlewis89
                    LG 47LB5DF blown power supply board
                    by cmlewis89
                    Hi folks,
                    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                    09-03-2024, 07:50 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • PlasMatt
                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                    by PlasMatt
                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                    09-20-2025, 06:50 PM
