LG 60PK550 plasma VA voltage going crazy
  • Yanleb
    • May 2017
    • 102
    I'm pretty much done with the diagnosis of this LG 60PK550 plasma TV. But I want a second opinion.
    The problem is that on startup the VA voltage is stable at 60 volts as it should be, then after 10 seconds it raises rapidly to 70 volts where the power supply shuts down to protect everything.
    By disconnecting various boards, I've isolated the problem to the lower left XL buffer board. When I disconnect the power cable (carrying GND and VA) between the Y sustaining board and the XL buffer board, VA on the power supply side stays rock steady at 60 volts. But on the XL buffer board side VA climbs instantly to >100 volts. Doing the same on the XC and XR buffer boards, VA climbs by itself to something that never go beyond 25 volts.
    Lucky as I am, I have second TV of the exact same model. Swapping all the boards from the good one to the bad one changed nothing at all.
    It's clear for me that something is back feeding some higher voltage into VA through one of the XL buffer board's panel connectors. I've disconnected all eight of them, one by one, trying to isolate a shorted vertical line, or a bad flex cable glued ship, but nothing stopped the voltage leak to the XL board VA voltage.
    What's your opinion on this one?
  • Yanleb
    • May 2017
    • 102
    Re: LG 60PK550 plasma VA voltage going crazy
    Anyone with an answer for my voltage feedback problem? Thanks.
    • Yanleb
      Schematic or datasheet for Plasma TV buffer chip
      by Yanleb
      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
      05-18-2022, 01:36 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Bad_Boards
      LG Plasma TV Bad Y Buffer Replacement
      by Bad_Boards
      Background:
      I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
      Question:
      Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
      Could I somehow check the Y-Sustain board to see if there was any damage done to it?
      04-07-2021, 09:39 PM
