Samsung UN55H6350AFXZA with "led halos"
  • engelwood39
    • Mar 2015
    • 93
    This TV had a bad power board. The power board had a thermistor that had completely broken a piece off and a blown fuse. I ended up purchasing a used to power board and replaced it when it came in. The TV then came on fine and worked, but appeared to have bright spots over almost the LED's wherever LED lights were. It seemed as if it was shining too bright on the LEDs and when you dim it the TV nothing really changes.
  • engelwood39
    • Mar 2015
    • 93
    Re: Samsung UN55H6350AFXZA with "led halos"
    Sorry, I thought I already uploaded the pictures with the initial post.
    • R_J
      • 9633
      I suspect it's the led's that are bad. see this thread https://www.badcaps.net/forum/showth...ght=rings+leds
      • chrismurphy
        • May 2014
        • 251
        • australia
        LED lenses have fallen off
        Remove panel and re glue
        Had this on a panasonic , fixed the faulty lenses , re glued with 5 m epoxy (superglue is not suitable)
        Also put dab of glue on all remaining lenses
        Worked well
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Originally posted by chrismurphy
          led lenses have fallen off
          remove panel and re glue
          had this on a panasonic , fixed the faulty lenses , re glued with 5 m epoxy (superglue is not suitable)
          also put dab of glue on all remaining lenses
          worked well
          +10
          • Diah
            • Feb 2013
            • 6614
            first compare the LED BL stage ( post resistor of currents) on the old PSU and the replacement one, it may the replacement one belong to other screen size.. if this not the case then i am with R J as we saw this fault over this forum too bad LED
            • Unspun01
              • Jun 2011
              • 349
              chrismurphy has a good point about LED lenses that have fallen off.. I repaired a 55" VIZIO 4K LED TV with 4 lenses that fell off. When I glued them back in place, I checked all other lenses, and they were ALL ready to fall off with only a small bit of lifting pressure from my fingernails. So I glued EVERY ONE.
              However, due to the uniformity of your issue, I don't think the lenses have fallen off. Rather, I suspect a few of the delicate plastic standoffs that hold the LCD panel and diffuser panels away from the backlights is damaged or bent inside the panel behind that area. This would cause the LCD and diffuser panels to "warp" and sit much closer to the LEDs and display intense backlight at this spot.
              I've repaired a few TVs with bent or damaged standoffs by heating the standoff with mild heat from a heatgun (160-180°C) or holding above a stove element and gently bending back to straight. If you do not use heat you risk snapping them or cracking them and I never see these for sale because they are not a high demand part... But they will be... They are making them weaker and weaker with newer TVs so you don't get any dimmer spots with them. But they "bend" under natural use.
              • engelwood39
                • Mar 2015
                • 93
                Well... Looks Like I am going to open it up and check LED lenses and also diffuser panel. This community is amazing! Thanks again!
                • engelwood39
                  • Mar 2015
                  • 93
                  I tore into the TV and found out that the spacers to give the diffuser (I think that's what is called) space away from the LEDs were broken. Somehow the screen must have had pressure on it at some point.. I took pieces of 1 inch clear tubing and they fit perfectly over the mount for the spacers. However it was leaving a dark Halo wherever the tubes were at so then cut them to a sharp Point minimizing where the tubing touches the screen. It ended up working really well. I'll post pictures To show just in case anyone else ever runs into this problem. It may not be a perfect fix but it actually worked pretty well.
                  • engelwood39
                    • Mar 2015
                    • 93
                    You nailed this with your diagnosis. A few of them were bent so bad they were completely broke and I chose to try a different solution other than the heat gun method. The clear tubing actually worked pretty good. Thanks for pointing me in the right direction!
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
