So there is one more Samsung TV which clicks and refuses to power up. When connected to mains, the red Standby LED lights up. When trying to turn the TV on, it clicks and doesn't fire up. The standby LED goes on and off in turn with the clicking.
TV Model: UE40C6000RWXXH
Power Supply: BN44-00357A, Schematic here.
Mainboard: BN41-01444B
What I have done so far:
- I have confirmed that there is standby voltage (the red LED goes on, duh
- A visual inspection of the power supply PCB shows no bulged capacitors and (on the back side) no bad solder joints
- All fuses are ok
- If I unplug the mainboard from the power supply and connect pins 16 and 18 together (PS_ON and STDBY on the CNM801 connector - to simulate the turn on signal) the LED backlight fires up immediately - so this indicates that the power supply should be ok...
So it looks like it's the mainboard, however I must confess that I have no experience repairing mainboards... I am no electronics expert but I have managed to cope with a lot of repairs of household appliances ... up to now
Maybe you could guide me what to check on the mainboard... and if a mainboard repair is at all possible... Any help will be highly appreciated
Thank you
)- A visual inspection of the power supply PCB shows no bulged capacitors and (on the back side) no bad solder joints
- All fuses are ok
