Wharfedale LCD37f1080p struggles to wakeup from standby.
  • Stickie
    • Mar 2019
    As mentioned in the thread title, my 37" Wharfedale TV struggles to wake up from standby.
    On plugging into the wall, the power LED will blink for a while (duration varies from minutes to hours). Trying to wake it up gets no response.
    Once I get a steady light, I can start trying to bring it out of standby. Pressing a button will, if it's warm, wake up the TV. If it's cold, or the TV has been off for a while, the power light will blink off, the screen may flicker on, the speakers may pop before the light comes back on and it goes back into standby.
    As I said, the problem seems affected by temperature. If the room is cold, it takes ages to get things going. If it's very warm, things seem fine.
    I don't know if this is connected, but there is nearly always a constant buzz coming from the speakers. It only goes away if the volume is set to zero - the buzz is otherwise unaffected by the volume controls.
    Once I get it up and running, it works fine.
    The power board is a 17PW20 V2, which I gather from reading other posts, are known for being problematic.
    I identified two caps - C818 and C857 - as being close to failure. The tops are noticeably bulging.
    I've ordered replacements and I'm confident I can get them in okay.
    Am on the right track? Could faulty caps at the positions I've identified cause problems like this?
    Another thought I had was, could it be possible to just completely bypass the Standby section of the board, so the power switch just turns the thing on?
    Would this be doable, and how complicated might it be?
    Hi everyone! I'm very glad I found this place.
    --S
  • R_J
    • Jun 2012
    • 9623
    Re: Wharfedale LCD37f1080p struggles to wakeup from standby.
    The standby circuit is need to turn the rest of the power supply on, so it can't really be bypassed. It is also likely some of the small electrolytics are also bad, but being small without vents you can't tell by looking at them. Post clear in focus pictures of the board
    It looks like C818 & C857 are on the 3.3 volt standby lines, I would also replace C860 & C830 if they are on that board
    and C817 & C838 for the +5Vstby
    Also replace C892 (10µf/50v) & C801 (33µf/50v)
    Note: some of these boards are very different and some components are not used on some versions
    • reessi
      JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
      by reessi
      I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
      You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
      Years ago it had some bulging caps...
      04-26-2021, 11:42 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • Crystaleyes
      Samsung BN44-00259A standby question
      by Crystaleyes
      Hi all.
      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
      08-11-2023, 05:15 AM
    • psssst
      Yamaha TSX 120 Standby Problem
      by psssst
      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
      03-01-2024, 07:25 AM
