lg 60pz550 black screen, no power, etc
  • legonch
    • Feb 2019
    • 49
    Ive got a lg 60pz550 tv, it had the purple bars across the top and bottom. I read on here how to fix that, and re soldered all the connections.
    When I put everything back together, I do not get the screen. Nothing. I hear the relays click.
    I have used an ohm meter to check all the fuses i can see on each of the boards, and they test out all about 1.6.
    I have the green led light flashing a pattern. i do have 120 volts going into the main board.
    I have tested the power going out to the ysus and vsus boards. One time, I did have power at the plug to the ysus board, but I can not duplicate that at this time. None of the connectors for the boards have any voltage detectable.
    I pulled the flat cable out of the av board, used a wire to jump in the holes, and screen will not display anything.
    Im suspicious of the main board, but confused why one time I did have voltage at the ysus connector.
    At this point I need some help. Im pretty tech savvy, can solder, etc. Thank you in advance.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: lg 60pz550 black screen, no power, etc
    You will have to post clear pictures of the boards and the whole back of the set.
    • legonch
      • Feb 2019
      • 49
      Here are the pictures as requested. Thank you for helping me
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        What did you re-solder? Just the coils on the y and z sus boards? There could be bad joints on the power supply. Check them out.
        • legonch
          • Feb 2019
          • 49
          I did just resolder the connections on the two boards. Tv powered up fine before i did that though. Dont see anything that i did that would cause the tv not to power up.
          i used an ohm meter on all the fuses. they all check out. I dont think i need to remove the fuses from the board to check them do i? They are soldered in type.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            So to be clear , you only fixed the joints on these parts circled in red?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Pic #1
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Pic#2
                • legonch
                  • Feb 2019
                  • 49
                  yes, thats all i touched. just disconnected the boards, resoldered the connections, and put back together. Nothing else
                  • legonch
                    • Feb 2019
                    • 49
                    I did some multi meter tests, pic shows where I have voltage and where I dont. One relay clicks when I plug it into the wall.
                    I have a long long short short pattern on the led light on the smaller board
                    I can not get tv to power on with the remote or by touching the button in front, this used to work before the solder as well.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      Here is a list of parts from a repair kit. Start with checking the 5v standby pin and then check the parts on the list.
                      • legonch
                        • Feb 2019
                        • 49
                        Im not sure where the standby pin is located. That the 5v labeled on the ysus and zsus boards?
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Stb or 5v should be on this connector.
                          • legonch
                            • Feb 2019
                            • 49
                            Okay, got a new multi meter. Attached is the pictures of each board with the noted voltages. I do have 5 volts on both the sus boards. on the left board, on the left lower side, the place to test voltage, i get 0 volts then 5 volts, and repeats.
                            Any ideas?
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              Watch this video. It should help you check everything.
                              https://youtu.be/aZF57Bok7Ws
                              • legonch
                                • Feb 2019
                                • 49
                                found some of the mosfets are grounded.
                                the second heat sink up from the bottom on the left board gets smoking hot, the rest do not. That mean anything?
                                Ive got the correct voltages going to each sus board.
                                • legonch
                                  • Feb 2019
                                  • 49
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    Which boards have the shorted fets? Do they have a Q for the position eg. Q421,Q602?
                                    • Tvbob
                                      tvbob
                                      • 204
                                      DO your self a favor.... Change the Sustain board with the shorted fet.s and check your buffer boards for shorts (there are youtube videos)
                                      You are not going to be able to check the gate drive components on you bad board and new fet's will POP. Ebay is a good source for used boards
                                      • Unspun01
                                        • Jun 2011
                                        • 333
                                        Should not need to replace the board. YSUS and ZSUS are easy repairs for this TV with ZSUS being more common failure mode.
                                        The heatsinks are too small for this TV and the 4633 IGBTs commonly run hot and short circuit leading to the failure. (Fairchild FGPF4633 330V PDP Trench IGBT). The gate driver ICs (Fairchild FAN7371) are usually ok, but can also fail sometimes. Any I've had to replace were shorted and easy to find. If you don't know how to check, you are better to replace all the bad IGBTs and their associated drivers with a kit from ShopJimmy:
                                        https://www.shopjimmy.com/lg-ebr7356...repair-kit.htm
                                        On my previous repairs, all of the other small surface mount resistors and components were ok and I didn't replace, but the fuse, the IGBTs and their drivers should definitely be checked.
                                        • grimacelord
                                          HP 15-EH1070wm - Black Screen With Power LED.
                                          by grimacelord
                                          I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                          First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                          01-28-2023, 10:50 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • rybby
                                          Acer Aspire 5 A515-51 power on but black screen
                                          by rybby
                                          I have an acer aspire 5 a515-51 that turns on but has a black screen.
                                          This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                                          Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                                          06-16-2023, 09:41 AM
                                        • burntonnerings
                                          Acer K272HUL blue power light but black screen, power supply is ok
                                          by burntonnerings
                                          Have had two Acer K272HUL monitors die with the same symptoms:
                                          - Blue power light is illuminated while the monitor is plugged in
                                          - Black screen (no splash screen, etc.)
                                          - Power button doesn't do anything
                                          Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                          Power supply voltages are fine.
                                          There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                          Anyone have any ideas?...
                                          12-09-2023, 10:22 PM
                                        • samolo75
                                          Asus Laptop GL702VS black screen power LED on
                                          by samolo75
                                          I am fighting with this laptop and I am suspecting of the GPU, but it would be great to know your opinion.
                                          The laptop originally does show black screen (no back light) but the power button LED turn on and off when pressing it.
                                          I did the next trouble shooting with no changes
                                          - Disconnected the battery and try just with the power supply
                                          - Disconnected all power sources, even the CMOS battery and held the power button for 40sec.
                                          - Disconnected hardrives
                                          - Deplaced the RAM
                                          - Disconnected the Wifi module
                                          - I connected a external monitor to the...
                                          03-31-2021, 03:16 PM
