Masthead amplifier power issue
  • Tom41
    • Oct 2005
    • 336
    • England
    We have a masthead amplifier on our outdoor TV antenna to improve reception, with a power unit indoors that sends +12v DC up the antenna cable to power it. But whenever a TV is connected to the antenna cable in the living room, all other TVs in the house go off and the PSU shows a red light instead of green. I just checked with a multimeter, and the masthead is sending the +12v straight back down into the living room instead of the signal! The other TV points in the house show no voltage on the antenna cable.
    The amplifier is designed to accept power from any of the TV points in the house, but it should not be sending the power straight back down into one of the TVs! Any idea how this happened? Has the masthead developed a fault, or did the installer get some wires crossed?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Masthead amplifier power issue
    It may be helpful if you say what make and model of the amplifier.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8064
      Maybe draw a little schematic, how you have your TV's and that mast mount pre amp set up and upload it here as an attachment. Then we can tell you what is wrong. If you put a DC blocker on that living room TV, then probably everything is going to be fine.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • justice171
        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
        by justice171
        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
        1. Verified that all critical voltages are present:
          • 3.3V and 5V are always present if DC is plugged.
          • 1.8V on the BIOS chip is present.
        2. Checked the power button functionality:
          • When pressed, the voltage drops to 0V, indicating the button is functional.
        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
          • Confirmed connectivity is intact, ruling out issues
        11-26-2024, 12:39 AM
      • claws77
        lenovo flex 5 14itl05 power sequence issue
        by claws77
        hi guys, my motherboard will not start no matter what
        when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
        but rest nothing happens no sign of life.
        this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
        with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
        but now nothing happens no matter how much i wait/ charge/ press and hold power button.
        i have no knowledge of motherboards ....
        10-20-2024, 02:48 PM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
