Panasonic TX-P50G20B Issues
  • Dizzwold
    • Oct 2018
    • 5
    Hi All,
    As the title subject state's, I have a Panasonic TX-P50G20B. Can someone point me in the direction of a service manual for this UK model? I've found the service manuals for the TX-P50S20B and the TX-P50G20E, are these accurate enough to work with?
    Before I get in to the thick of the issues, do I need to be in the service mode to get the Power LED Blink Code?
    The issues started with a very slow EPG, then a week later or so, once the tv "had warmed up", you would get a black screen and not able to change channel. It may take me a day or two to be able to test this unit, to move it away from dog's and children etc, but I'd be grateful for any advice.
    Best UK supplier for replacement boards?
    Regards.
    Dizzwold.
  • HKS00
    Panasonic CF-20 Track pad issues
    by HKS00
    Hello Everyone,
    My name is Haris and, I am new to the forum. I would appreciate any help I can get.
    Little back story on me and the issues that we are dealing with...
    I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
    03-08-2023, 10:34 AM
  • newgen2005
    Panasonic DMR-ES30V power issues
    by newgen2005
    I picked up a Panasonic DMR-ES30V (UK). When I first plugged in there was nothing, appeared completely dead, I then turned it on and off a couple of times at the mains supply and it came on. It accepts a cassette but then spits it out straight away, the DVD drive functions sometimes but then the unit turns off with nothing on the display. I took the back off and noticed the fan does not spin. The display for the DVD side does seem a little dim when it is working.
    I have looked on google and people say it is most likely a capacitor/s.
    Just looking for some advice on which...
    09-26-2024, 03:49 AM
  • gre0013
    Panasonic TC-59R62 Overscan issues. How to adjust?
    by gre0013
    Hello. I need help opening the service menu on a Panasonic TC-59R62
    Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
    Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
    07-26-2024, 10:14 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • RooTV
    Panasonic TH-65AX800A PSU Issues?
    by RooTV
    Hi all
    I have a Panasonic TH-65AX800A that turns on for about 2 seconds and then turns itself off.
    I got it like this hoping it was just a bad cap and an easy fix.
    I have pulled the power board and cannot see any obvious capacitor damage.
    Is there any other likely causes? Anything else I should check for?
    The power board is
    TNPA5937 2P
    with an additional silver sticker saying
    A1318VAL
    TNPA5937DA
    V1434
    I have tracked down another power supply which has the markings
    TNPA5937 2P...
    04-19-2021, 02:39 AM
