I have repaired 10 or so A series Samsungs with the c102 green screen/screeching problem. In those cases the tv would click on and off with the screen and sound problem. I fixed a 46" model today That turned on fine and the no video and input menus were fine. Only when you turned on a device plugged into the mainboard(hdmi/component) it would turn into the classic c102 fault. A new 47uf smd cap solved it.
C102 in LN46A580P6FXZA
by peter99helo everry body!!!
My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
- If not power on, battery charge ok.
- if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
I replaced the BQ 25A charging IC but the device only charges when not turned on.
everyone please help me with solution, what should i do ?
thanks a lot !!!!!... -
by bykanovmLenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
Also, the laptop does not turn on without... -
by ZiliconHearty greetings to everyone, trust you all are doing excellently well.
Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
The power stables in very rare case. Once it was stabled, everything works fine.
Once the power switched is pressed, 5V and 3V were present.
The things i have done:
1. I have check for shorts on the board, but nothing. The board is short free
2. Not a power switch problem, it behaves the same without the switch ...06-10-2024, 05:05 AM -
by mialiveloHi! I have asus rog strix scar 2 gl504gw! the battery drains when computer is turned off! Can you help me please?05-22-2024, 08:02 AM
by kamil1986Hello everyone.
Laptop Dell Latitude E5530
Płyta: LA-7902P REV:1
KBC: MEC5055-LZY
Procesor: intel i3
The laptop turns on but does not display the picture, after pressing the power button fan does not spin, the motherboard is stuck at 600mA current consumption the CPU and PCH chip gets warm. When I press again power button the fan start to spin but after a couple of seconds the motherboard turns off itself and current consumption drops to 12mA. The motherboard correctly displays fault codes because if I turn on the motherboard without RAM...03-19-2022, 11:28 AM - Loading...
