Toshiba 40l1333b (SSL400_05DA) - backlight problem
  • dfear
    • Mar 2013
    • 53
    I have a Toshiba 40l1333b with a backlight problem.
    Problem:
    The backlights don't light up.
    Screen: Lta400hm23
    LED Driver board: Ssl400 0d5a- Rev 1.0
    Back light LED Strip connector board: SSL400_WP01 REV:0.0
    Firstly I replaced the driver board, but that didn't fix the problem.
    with the replacement driver board connected, I tested the led strips with an LED tester and all the leds light up.
    I tested the leds using test points VOUT and IS (which are on the led driver board).
    Also i have checked the continuity from the led driver board to the led strips, and continuity is OK.
    I think there is a fault with the led driver board. I have attached two photos of the led driver board. The photo with just black test shows what the voltages should be at various points (i found these voltages from a photo I found on a forum). The second photo ( with the green text) show the results of testing the replacement driver board.
    Any clues which component on the led driver board in faulty?
    Update: I replaced the SN358 op-amp with with a LM358, but it made no difference.
    Here is a number of photos with varying test results
    correct voltages on SSL400_05DA
    http://testing.dfear.co.uk/toshiba_4...ack%20text.png
    results of testing original SSL400_05DA (from the tv)
    http://testing.dfear.co.uk/toshiba_4...%20results.png
    results of testing replacement SSL400_05DA
    results of testing SN358, TR10E and CN001 - original SSL400_05DA
    results of testing SN358, TR10E and CN001 - replacement SSL400_05DA
    Re: Toshiba 40l1333b (SSL400_05DA) - backlight problem
    When you test the whole LED strip with the LED tester, what Voltage does it show on the tester?
    • dfear
      • Mar 2013
      • 53
      I have tested all 5 of the rows of led strips (each row is a pair of strips). The positive probe of the tester was on positive testpoint on the first strip of the last row of leds and the negative probe was on the IS testpoint on the SSL400_05DA. The voltage on the tester was ~141 V. The test was done with the cable connected to CN001 on SSL400_05DA.
      Individual rows are about 20-23 V per row. 2 rows have 2 strips of 4 leds and 3 rows have 1 strip of 5 and one strip of 4 leds.
      • dfear
        • Mar 2013
        • 53
        The negative side of the connection between the two led strips on the last row seems to be dead at present, so that will need fixing.
        Is it worth replacing all of the links between the led strips on all the rows with wire or rigid metal jumpers?
        • zomi
          • Nov 2011
          • 507
          Jumper the links
          its a known issue on this model
            Yep, bypass those surface mounted connectors on the strips with jumper wires.
            • zomi
              • Nov 2011
              • 507
              Once bypassed then retest
              sometimes with the led tester all works fine but on the tv it doesnt
              due to increases resistance on those points..
              • dfear
                • Mar 2013
                • 53
                Originally posted by zomi
                Jumper the links
                I have fixed the backlight broken on this TV.
                The problem was the crappy connectors that connect the led strip pairs together.
                Solution:
                I have soldered solid copper wire jumpers between the pairs of led strips. Only one connection was faulty but I put copper jumper wires between all of the led strip pairs, on both the positive and negative connections.
                FYI:
                The voltage on the LED tester (after the repair), when putting the probes on the IS and V_OUT test points on SSL400_05DA, was 124V.
                FYI:
                I used the solid copper wire from 1.0mm2 twin and earth electrical cable to make the jumper links.
                https://obrazki.elektroda.pl/7825770300_1541702334.jpg
                  Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                  09-06-2024, 05:33 AM
                  Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                  09-06-2024, 05:30 AM
                  Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
                  Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                  09-06-2024, 09:01 AM
