Panasonic TX-P50GT50E
  • Dejan84
    • Oct 2018
    • Serbia
    Hi guys i have Panasonic TX-P50GT50E and need eeprom for IC9304 and IC 8902. I just can't find them anywhere...
    A-board is TNPH0988 1 A.
    The TV has 13 red blinks problem. When I plug power cord it starts and stays on smartviera logo for 2-3min then reset itself and
    do the same thing one more time. After that it goes to 13 red blinks.
    Panasonic service manual says it's Emergency SOS from A-Board.
    All check ponits for voltages are fine only STBY5V on power supply is 4.48v.
    This A-bord is very difficult to find so I have to get it fixed...
    My only guess is to reflash eeprom's but i cant find them.
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Panasonic TX-P50GT50E
    You can try flashing the firmware using an sd card
    • Dejan84
      • Oct 2018
      • Serbia
      Problem is that it just show smartviera logo and stays that way. Trayed on SD and USB1 same thing.
      • FixyNeko
        • Feb 2020
        • France
        I had the same problem on my TV ( Panasonic Tx-P65vt50e). Not exactly the same model, but same board (tnph0988).
        The processor's thermal pads were dry and it cooked itself to death. I reflowed it with a hot air iron at 180°C, but you can do the same with an oven, 180°C for 10mn.
        Maybe it's too late for you, but it may be useful to another person
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • CrewmanRedShirt
          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
          by CrewmanRedShirt
          Hello all,
          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
          07-13-2024, 11:02 AM
