Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Emerson - LF320EM4 A
    No photos found.
  • xbliu.cn@gmail.com
    ASUS ROG Zephyrus G14 GA402R – 19V present but no 3.3V/5V standby, no power
    by xbliu.cn@gmail.com
    I’m looking for help diagnosing a no-power issue on an ASUS ROG Zephyrus G14 (GA402R / GA402RK series). ā— Problem
    The laptop does not power on at all:
    • No LEDs
    • No fan spin
    • No response to power button
    The issue started right after a RAM upgrade. The previous owner mentioned there may have been static discharge during reassembly.
    šŸ” What I have checked so far (with a multimeter)
    • AC adapter is confirmed working
    • 19–20V is present at the DC jack
    • Both input MOSFETs have 19–20V on both sides
    • Multiple inductors near the eDP connector
    12-13-2025, 11:40 PM
  • Benass
    AVT150 stuck in standby (mute) – standby pin at 0 V unless T104 is removed
    by Benass
    I am troubleshooting an AVT150 amplifier. The standby pin is at 0 V, so the amp remains muted.
    I have the schematics attached.
    Key observation:
    • The standby pin is 0 V (muted condition).
    • If I remove T104, the standby voltage is restored.
    • With T104 removed, I have 4.7v on standby pin and TDA can see signal generated.
    This suggests T104 (or its surrounding circuitry) is pulling the standby line low, but I am not yet certain whether this is due to a faulty transistor, a control signal upstream, or a protection condition being asserted.
    Has anyone...
    01-12-2026, 02:57 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • Crystaleyes
    Samsung BN44-00259A standby question
    by Crystaleyes
    Hi all.
    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
    08-11-2023, 05:15 AM
