Re: Emerson - LF320EM4 A
Post your non-working dump here, I'll try to fix it.
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Hi ,I need the bin file too for TV emerson LF. 320EM4 A
.Leave a comment:
If there is a bad EEPROM, there is about a 75% chance, that the TV turns back on again using this trick. If it does, you could do it again and read the EEPROM and copy it to a new EEPROM. A bad EEPROM in those Emerson TV's can prevent the TV from turning on.Leave a comment:
freeze the eeprom with a can of air upside down and then turn the tv on.Leave a comment:
Unit in standby mode only.
Does not turn on
Anyone with a good bin file here?
ThanksTags: None
Iām looking for help diagnosing a no-power issue on an ASUS ROG Zephyrus G14 (GA402R / GA402RK series). ā Problem
The laptop does not power on at all:- No LEDs
- No fan spin
- No response to power button
The issue started right after a RAM upgrade. The previous owner mentioned there may have been static discharge during reassembly.
š What I have checked so far (with a multimeter)- AC adapter is confirmed working
- 19ā20V is present at the DC jack
- Both input MOSFETs have 19ā20V on both sides
- Multiple inductors near the eDP connector
8 Photos -
by BenassI am troubleshooting an AVT150 amplifier. The standby pin is at 0 V, so the amp remains muted.
I have the schematics attached.
Key observation:- The standby pin is 0 V (muted condition).
- If I remove T104, the standby voltage is restored.
- With T104 removed, I have 4.7v on standby pin and TDA can see signal generated.
This suggests T104 (or its surrounding circuitry) is pulling the standby line low, but I am not yet certain whether this is due to a faulty transistor, a control signal upstream, or a protection condition being asserted.
Has anyone...-
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by CrystaleyesHi all.
I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
... - Loading...
