Samsung Plasma PN60E550D1F Power LED Blinks, Appears To Come On, No Display
  • Michale32086
    • Nov 2011
    • 1453
    Re: Samsung Plasma PN60E550D1F Power LED Blinks, Appears To Come On, No Display
    OK I have completed my homework assignment....
    I felt like a pygmy amongst giants..
    I am seriously just a knuckle dragging ground pounder who has a VERY basic grasp of this stuff..
    Most of what I do here is to simply buy parts until it's fixed.. I get in 20-30 TVs every week and my process is that, if it can get fixed in a couple hours, put it aside until another identical model comes thru that's working (or can be quickly fixed) and then use it to diagnose previous ones..
    I do sincerely appreciate your efforts and apologize if my shortcomings were frustrating
    for you...
    I am still going to keep this one alive... See if I can get some working parts for it.. I'll loop you in if I get another one in, which happens more often than you might think...
    Thanx again for your time and efforts..
      09-07-2024, 05:50 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
    • M80
      Samsung PN51E550D1FXZA plasma no power up 2 blinks
      by M80
      Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
      ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
      Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
      I've reseated ALL connectors and none of the boards have any burned traces or...
      08-11-2022, 04:34 PM
      09-06-2024, 11:40 PM
