Sony KDL-50W800C
  • n3lka
    • Jan 2014
    • 84
    Sony KDL-50W800C
    Having a strange issue, just wanted to know if anyone's seen this issue before. I'm getting shadows on bright spots on my picture. It doesn't happen all of the time, but is progressively getting more persistent. I'm thinking main board or tcon, but more the main board.
    I've tried changing picture adjustments, etc. Half tempted to buy a new tv and work on this one at my leisure.
    Here's link to my googledrive with some examples. Let me know if anyone's seen this before. Tempted to contact Sony. Not expecting them to fix it, would just like what to replace.
    Pictures: https://drive.google.com/drive/folde...Oq?usp=sharing
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-50W800C
    Looks like the Panel is going bad, to me.
    • n3lka
      • Jan 2014
      • 84
      Almost looks like a GPU issue I've seen on PC's. Hoping not the panel. Emailed Sony support to get their input. It's not constant, just with brighter contrasting colors. If I adjust the contrast or black level. it does change, but doesn't go away.
      • mmartell
        • Oct 2013
        • 3189
        I would guess main or tcon. Maybe measure the voltages on the tcon to see if something there is out of whack.
        • n3lka
          • Jan 2014
          • 84
          I may have just lucked out. The TV is under a 3 year warranty from the date it was shipped. I received it back in May 2016. Even if they go by mfg date, it was made in October 2015. The Video gods are smiling upon me for once.
          I'll let everyone know how I make out and what the issue is if they repair vs. replace.
          I did do a factory reset and checked the firmware levels...all good. Going to do a power reset as recommended by Sony then if that doesn't work then call warranty support.
          It's getting worse, on dark scenes, getting red blotches/shadows. On bright white areas, getting blue blotches, and in Yellow, Green blotches.
          Whatever it is, thank goodness they have a 3 year warranty. Bummer is, I just sold a TCL 48" tv that I fixed instead of keeping it for a spare. Next tv I fix goes into storage for future spare usage. I have tv's in other rooms, but the wife likes to watch tv in the living room.
          • n3lka
            • Jan 2014
            • 84
            Now Sony tells me 2 year warranty. Going to buy a main board and try it. from the symptoms I've seen of TCons, this doesn't match it. If the main board doesn't fix it, I can always resell, then I'll get a TCon.
            • Aakashlimbu
              • Apr 2022
              • 5
              • Nepal
              Your link is not working.send me a pic. I will guide you
              • dskall
                • Oct 2016
                • 2905
                • usa
                These are old posts. Links no good after 4 years.
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                  09-06-2024, 05:30 AM
                  Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
