pn50b450b1d clicking
  • pop70458
    • Jan 2012
    • 103
    The tv clicks and sometimes makes the chime sound but will not power on the whole way.
    Va and Vs don't have any voltage.
    When i jumper the board i only get 168v on the main caps when powered on.
    I get all of the correct voltages on the connector that goes to the main board.
    The power supply is a bn44-00274a
  • pop70458
    • Jan 2012
    • 103
    Re: pn50b450b1d clicking
    I ordered a new power supply and the tv powered up but it has some horizontal black lines.
    Is there a way that i can narrow it down to a bad panel or y sus or buffer problems?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      This sounds like a Y-SUS and Y buffers problem. I would recommend changing the Y-SUS and Buffer Bds. together.
      • meeotch
        Samsung PN64H5000 clicking when powered, then stuck in standby
        by meeotch
        My PN64H5000 shut itself off/on/off a few times in succession last night, then refused to turn on again. When I first plug it in, I get five clicks coming from the power board, and the red standby light on the front goes on and off, as does the little green LED on the logic board. After that, the red standby light comes on after a couple of seconds and stays lit, but the TV will not power on. Confirmed by leaving it unplugged overnight.
        I opened it up, and didn't see any bulging caps, burnt PCBs, or anything else obvious. Tested the two fuses I saw on the power board (one removable,...
        09-27-2021, 02:57 PM
      • B0r1s
        Samsung UE49KS7000SXXH - fast clicking sound in standby mode
        by B0r1s
        PSU - BN44-00878A
        Symptoms:
        The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
        A weak clicking sound was coming from the transformer.
        Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
        Progress:
        After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
        01-17-2023, 04:58 PM
      • EvazX
        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
        by EvazX
        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
        However, after some time, the replacement motherboard...
        08-25-2025, 06:09 PM
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • Sisko
        Onkyo-593 No power and now clicking sound
        by Sisko
        Hi all!!
        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
        10-03-2025, 02:18 PM
