LG 42" Plasma TV model 42PT350R with darkish image and sparklies
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi guys. I need your assistance once again. I have this tv whose y-sus board had some shorted out igbt's. I replaced all faulty stuff and then the tv came on. I just saw a bad dark picture with sparkles.
    I wrote down all the voltages which seemed spot on.
    They are,
    Vs=201V
    Va=55V
    Vy=-200V
    Vzbias=125V
    They match what is on the panel.
    The only other thing and i took a photo of is the fact that the plasma display has a yellow tinge instead of a matt black color. I suspect that to be panel ageing.
    Why is my picture so dark and sparkly...?
    Kind regards
    Angelos
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Re: LG 42" Plasma TV model 42PT350R with darkish image and sparklies
    So sorry. I realise now i put this on the wrong thread. Ive veen using my cell phone and everything is so small i couldnt read well the heading. Shouldbi repost?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Thread moved
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Look for loose/cold solder joints on the Z-Sus Bd.
        • angelos
          • Dec 2012
          • 571
          • South Africa
          I just want to get the terminology right. Is the zsus also called the xsus. The one with the two wide ribbons on the right?
          • R_J
            • 9546
            Looking from the back, Y-sus is on the left and Z-sus is on the right, a few mfg. call it the X-sus, then there is Panasonic
            • angelos
              • Dec 2012
              • 571
              • South Africa
              I have a proper digital storage oscilloscope. What kind of a waveform can i measure to ensure proper operation. I have a x100 probe if need be?
              • angelos
                • Dec 2012
                • 571
                • South Africa
                Hi Guys, just an update. I have not had much time lately to continue with this tv but i did notice something. If the TV has been switched off for a couple of days then when you power up the TV you get the following image which progressively improves. I attached a photo for you to see. Would you still say it's the Z-Sus or X-Sus????
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Z-sus issue Faulty or very bad joints
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Since this is a LG TV it is properly called a Z-Sus Bd.
                    • angelos
                      • Dec 2012
                      • 571
                      • South Africa
                      Well about 5 minutes after taking the photo the ysus board short circuited again. Are there repair kits for these available?
                        It failed because you are running it for too long with a bad z-sus, this will cause extra stress on the board because of the lack of energy recovery. These cheaper TVs use a shared energy recovery circuit to reduce costs but it can make for tricky repairs.
                        Repair kits are availability but availability in South Africa may be the issue.
                        You can replace the IGBTs and gate driver ICs that have failed - UTSource is a good place to go
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • piershs
                          Toshiba plasma 50WP16 wierd double image fault
                          by piershs
                          My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                          Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                          • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                          • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                          08-01-2020, 01:07 PM
                        • Delired73
                          TV LG 50PA4500 Plasma : bad image noisy
                          by Delired73
                          I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
                          Originaly the TV stopped to work and didn't want to turn ON again.
                          After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
                          It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
                          I check Vs and Va voltages...
                          04-04-2021, 09:13 AM
                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          09-06-2024, 10:56 AM
                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
