Salora 24LED6215CDW delayed/no sound.
  • Nikolai Tesla
    • Oct 2016
    • 28
    • Netherlands
    L.S.,
    I have this tv which is made in the Lithuanian Tauras factory, which doesn't excist any more from what I heard.
    The problems are:
    -when the volume is low, a very short period of loud sound (a brief moment)
    -no sound after a few hours
    -The sound is not synchronious with the picture, but delayed.
    The mainboard is a HK-TSP.9202P63.
    The screen is a LK235D3HAOS.
    This is a DVB-C/DVB-T tv with a build in DVD player.
    What I did is to resolder some IC legs with hot air....the intermittent loud sound is not cured....the rest has to be discovered.
    A service manual, the eprom data, or just some repair tips is highly appreciated.
    Im looking forward to hear from you!
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • eduaqa
    Amplifier - bad sound when loud sound on bass
    by eduaqa
    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
    08-06-2022, 11:28 AM
  • proxneo
    Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
    by proxneo
    Dear reader
    I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
    12-02-2023, 09:27 AM
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
