Samsung UE32C6730 , Horizontal lines. Panel?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Found this tv in the trash. Panel looked ok from the outside so i thought ill take it home.
    Turned it on and saw these lines on the screen. Reseated all the cables but no visible changes.
    I think it is a bad panel. Removing 1 side of the tcon shows 1 half black screen , other side removed shows the whole screen with lines but less picture on 1 side.
    Anyone got any experience with these models? Dont think its bga on mainboard? It has a separate gpu though....
    Thanks.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung UE32C6730 , Horizontal lines. Panel?
    Pictures of the boards. Any thoughts on the coil?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Capacitor C43 reads 0.8 ohm. Might be shorted capacitor that is causing the problem.
      Can i remove it? I read somewhere on this forum that people fix these problems with bad capacitors.
      Sorry , never repair these tv's haha.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Sorry. That is a bad panel. Not T-CON Bd or Main Bd. Taking one side of T-CON Bd off gave both sides picture is a bit strange.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Hmm maybe not! Pressing on this small ic makes most lines go away.
          Will try to resolder the part.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Does this Panel have Gate Tabs at the side?
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              No does not have gate tabs , was thinking the same by removing them on 1 side. I pressed the t-con at that area and the lines almost went away or got back at the whole screen. Im now 100% sure the t-con is the problem. Reflowing the resistors/caps did not help but it improved a little.
              Will replace the t-con.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                I found out via a local repair man that these mainboards are the issue. When you bend it a little the lines go away. I can confirm it.
                Solution is replacement of the mainboard.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Heat up the BGA chip with a Hot air Station if you have access to one 350C at fan speed 4 for 10 min.
