samsung model code pn51d530a3fxza
  • archery1
    • May 2018
    • 14
    • usa
    Samsung Model s50fh-yb10 , Having trouble with our plasma tv. Plug it in and i hear the dreaded clicking sound. So i unplugged it let it sit for alittle and took back panel off. I unhooked all boards and tried to power it on. nothing happened. Waited alittle hooked 1 board up at a time. Nothing. It only clicks when all boards are hooked up. The clicking sound seems like it is coming from this metal heat sink or?
    The green light on other board will flash a few times when i hear the clicking sound. could this be the sustain or or buffer.
    I am not sure where these are located. Also when working on this tv. I do realize it stores enough juice in it to kill you. How long should i wait( unplugged ) before i start messing with sustain ,buffer or other similar parts.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: samsung model code pn51d530a3fxza
    That clicking sound is a good sign that the PSU is OK. Could we get clear pics of the back of the TV so we could see how the boards are connected and close up shots of each board? That will give you more responses as then we can see what you are speaking about.
    • archery1
      • May 2018
      • 14
      • usa
      Originally posted by andrew f. Ali
      that clicking sound is a good sign that the psu is ok. Could we get clear pics of the back of the tv so we could see how the boards are connected and close up shots of each board? That will give you more responses as then we can see what you are speaking about.
      • archery1
        • May 2018
        • 14
        • usa
        Don't no why my pics are upright when i took them and uploaded,but when i looked at them on my thread they are all crazy side,upside down views..
        • archery1
          • May 2018
          • 14
          • usa
          here is a pic of whole back of tv
          don't no why its upside down..shows correct on my computer before i uploaded it.
          • archery1
            • May 2018
            • 14
            • usa
            Re: samsung model code pn51d530a3fxzamodel s59fh-yb10
            ttt
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              First let's test your PSU and see if it is OK.
              Look at connector J821 on the PSU. With your DMM black probe connected to the chassis GND and the red probe on Pin 1or2 plug the TV in the ac and see if you have a steady 5.3Vdc. I can't see where a StdBy 5V would be .If you do. Unplug the TV from the ac. Wait for 10 minutes and unplug the jack going from the PSU to the Y-Main Bd. I can't see clearly what the No. is. Jxxx?? Anyway it should have the marking VS and GND on 2 of the wires.
              • archery1
                • May 2018
                • 14
                • usa
                tested psu getting 5.18-5.19 . When i powered tv on no pic,just black screen , no clicking sound though. tv powered up red light stayed on front of tv and also green light on psu stayed on. tested fuse on psu it read 1 on tester
                  What does it show on your meter (set to Ohm mode, no power apply to the circuit) if you touch the two probes of your meter together? That is what is should show when you test the fuse.
                  '1' usually means over range = blown fuse.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Originally posted by budm
                    what does it show on your meter (set to ohm mode, no power apply to the circuit) if you touch the two probes of your meter together? That is what is should show when you test the fuse.
                    +1
                    • archery1
                      • May 2018
                      • 14
                      • usa
                      Originally posted by Andrew F. Ali
                      +1
                      reads 1 . when i have it set to 200k reads 1 when i have it set on 2000k
                      reads 1 when i have it on 20k
                      this cen-tec meter is JUNK!!!
                      i WILL BE GETTING A FLUKE REAL SOON.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        1 reading on your meter indicates a blown fuse.
                        • archery1
                          • May 2018
                          • 14
                          • usa
                          ok. I got a better meter not the best by far but alot better than what i had. My local hardware store didnt have any flukes so i bought a ideal 61-340. Tested fuse it is good tested the dc on pin connector j821 on psu with the y board disconnected i got a current jumping around and now the tv clicks several times. I did notice when i plug tv on the red light on front blinks 7 times. I will hook up y board and try soon.
                          • archery1
                            • May 2018
                            • 14
                            • usa
                            hooked y sus board up now i get clicking sound. Am i right on this? if the y sus board is bad shouldnt i replace the lower and upper y drive boards or just the upper?
                            • archery1
                              • May 2018
                              • 14
                              • usa
                              Can anyone help?
                              • geeforce
                                • Oct 2017
                                • 87
                                Did you get anywhere?
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  This thread slipped thru the crack. Really, did you reach a conclusion??
                                  • B0r1s
                                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                    by B0r1s
                                    PSU - BN44-00878A
                                    Symptoms:
                                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                    A weak clicking sound was coming from the transformer.
                                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                    Progress:
                                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                    01-17-2023, 04:58 PM
                                    09-07-2024, 05:50 AM
                                  • slimmy182
                                    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                    by slimmy182
                                    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                    Looking on google I found this:...
                                    01-14-2023, 11:55 AM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • jchang
                                    Samsung UN70NU6900F no picture and no sound
                                    by jchang
                                    Hi all
                                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                    Symptom:
                                    No picture no sound.
                                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                    No sound at all.
                                    What I tried:
                                    1. I tried unplugging the left or right ribbon...
                                    01-09-2023, 06:28 PM
