samsung s22a450bw
  • Pascal Komlassan
    • Jan 2017
    • 808
    • TOGO
    samsung s22a450bw
    HELLO ¨PLEASE I NEED THE BIOS DUMP OF THIS samsung s22a450bw
  • Pascal Komlassan
    • Jan 2017
    • 808
    • TOGO
    Re: samsung s22a450bw
    any help please
    • R_J
      • 9625
      What is wrong with your bios? I found this file S22A450BW-LTM220MT09.rar listed on a chinafix.com, you need to join to download the file.
      There is also a file: S22A450BW.zip here : hxxps://www.elektroda.pl/rtvforum/topic3451452.html
      • Pascal Komlassan
        • Jan 2017
        • 808
        • TOGO
        my screen turns on but if I plug the cable VGA or DVI it does not come.the image does not show
        • Pascal Komlassan
          • Jan 2017
          • 808
          • TOGO
          thanks to you i found the dump on a Polish site
          • R_J
            • 9625
            Glad to here you found it, and thank you for posting it here, it will likely help someone else.
            • datodati962@gmail.com
              • May 2020
              • 48
              • alb
              hi,i have the same model but i dont cant control menu,model is S22A450mW
              can please ssend me any working bin file for ths monitor?
              thanks
              • R_J
                • 9625
                thanks
                Did you try the one in post #5?
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • unimatrix93
                  SAMSUNG UE58MU6122 dump file needed
                  by unimatrix93
                  Dear Community,
                  I have a Samsung UE58MU6122 with no power LED.
                  I checked the PSU, all output voltages are present so it's probably good.
                  Doing some research I found that the corruption of the SPI memory chip can cause this problem and the TV started acting like this after a power outage.
                  Can somebody please provide a dump file so I can flash it to the IC?
                  Thank you!😊
                  02-29-2024, 03:15 AM
                  09-07-2024, 05:50 AM
                • GeckoGreen
                  Samsung service bulletin: need firmware file for PN63C550 TV
                  by GeckoGreen
                  I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                  You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                  The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                  Will you please help me get the [2D63]LOGIC.bin file for my TV?
                  05-17-2025, 02:47 PM
                • G11NS
                  Samsung Subwoofer HK-450 Transmitter Dump file repair
                  by G11NS
                  Hi, need help to fix my dump file....
                  It was Samsung Subwoofer HK-450 Transmitter
                  Model : WISP-40A RX1
                  P/N : AH59-02738A
                  FW : R140
                  Thank you for help.......
                  02-25-2023, 10:34 PM
