Toshiba 49L621U
    replied
    Re: Toshiba 49L621U
    Originally posted by kristapMA
    Here is a pic of the bottom of that board.
    I am talking about the bottom soldered side of the board.
    replied
    Re: Toshiba 49L621U
    Must be error on your meter or how you have the probes connected, or meter setting or meter is dead since now you are getting basically 0V.
  • kristapMA
    replied
    Re: Toshiba 49L621U
    Originally posted by budm
    Something does not look right: pin 1,2, and 3 16V2. What does it mean 'ALL THE WAY'?
    Pin 8 is also 16V2 but you show '0V', it should show the same as pin 1 ~ 3.
    Please verify your measurement.
    I redid the pins and got different numbers. I must be doing something wrong then? I don't get it... my son took a video while I was doing it, maybe someone can tell me what i am doing wrong... I am trying to figure out how to upload the video from my phone and will post when i figure it out.. in the mean time here are the numbers i got...
    Standby
    1 - 0 - 16v2
    2 - 0 - 16v2
    3 - 0 - 16v2
    4 - 0 - gndp
    5 - 0 - gndp
    6 -0 - 16va
    7 - 0 -gnda
    8 - 0 - 16v2
    9 - 0 - gndp
    10 - .2 (ish) - 5v1 - needle moved a tiny bit
    11 - 0 - acd
    12 - 0 -pwon
    13 - 0 -blon
    14 - .2 (ish) - 5v1 - needle moved a tiny bit
    15 - .2 (ish) - dim
    capacitor - 0v
    capacitor - 1v
    POWER ON
    1 - 1 - 16v2
    2 - 1 - 16v2
    3 - 1 - 16v2
    4 - 0 -gndp
    5 - 0 - gndp
    6 - 1 - 16va
    7 - 0 - gnda
    8 - 1 - 16v2
    9 - 0 -gndp
    10 - 0 - 5v1
    11 - .2 ish acd
    12 - 0 -pwon
    13 - 0 - blon
    14 - 0 -5v1
    15 - 0 - dim
    capicitor - 3v
    capicitor - 3v
    i can't figure out how to attach the video so I uploaded it to youtube. https://www.youtube.com/watch?v=3jhNrz11i9Q
  • kristapMA
    replied
    Re: Toshiba 49L621U
    BTW, can I get straight shot pictures of the whole bottom side of that power supply board Toshiba PK101W1230I?
    Shopjimmy does not have it.
  • kristapMA
    replied
    Re: Toshiba 49L621U
    Originally posted by Diah
    you have TOSHIBA LOGO show on screen at start on. this is much belong to glitch at firmware. as TOSHIBA very known with poor firmware. there are update from August 2017 to this model . download it and follow how to PDFfile with same link. you must match the firmware to your model size in your case 49 to let the INIT_CLEAR.prg work at start up when you plug in the USB first then the electric wall cord
    if this didnt help you. i go to judgment the Background edge LED one of line are shorted
    can i update the firmware if i can't see the screen?
    I am getting ready to do the testing from a few posts up as I haven't done that yet but not sure how to update the firmware as i have never done that before.
    replied
    Re: Toshiba 49L621U
    https://www.ebay.com/itm/Toshiba-49L...UAAOSw1J5aowFW For 20 bucks and free shipping, I'd give that a shot.
  • hoodyracoon
    replied
    Re: Toshiba 49L621U
    yeah my tv doesn't have a firmware update on Toshibas site anyhow, so its like i thought if i have a issue with firmware i would need to flash it via a eprom flasher or rs232, and thats if i could get the file, don't think it is just looking at my options
  • hoodyracoon
    replied
    Re: Toshiba 49L621U
    didn't see the mention of them seeing the logo, yeah i don't, still think mine is a led issue but get got a multimeter so i can check the led voltages, so ill see, hope its not a eprom issue for me since i don't have a way to flash it unless it has a rs232 header/set of pads
    replied
    Re: Toshiba 49L621U
    +1, you can solve a lot of problems with a firmware update, learned that the hard way.
  • Diah
    replied
    Re: Toshiba 49L621U
    By legs do you mean in the green circle that I have marked?
  • hoodyracoon
    replied
    Re: Toshiba 49L621U
    either way if its not the LEDs the psu is still only 30$ and ive basically ruled out tcon because the issue persists when i unplug it(and it wouldn't flash the backlight if it was tcon), it doesn't seem likely to tpbe the main board either, but who knows, like i said im voting bad led shorting out the LED driver leading to over current protection
  • hoodyracoon
    replied
    Re: Toshiba 49L621U
    by fraction i mean fraction of a second, probably less then a 5th of a second, definitely not slow enough to verify without a video going frame by frame
  • hoodyracoon
    replied
    Re: Toshiba 49L621U
    interesting thread, i have a 1080p version of the same tv that has the exact same issue, same psu board. i believe it to be a shorted led leading to over current protection based on the fact the middle of the screen is slightly dimmer then the outside in the fraction of a second that the backlight runs, i tested this by taking a video of me pluging the tv in and recording the flash on screen, could be the same issue, if so the led strips like 20$ on ebay
    replied
    Re: Toshiba 49L621U
    Yes, need the Voltages of both caps when TV is OFF and when TV power switch is activated, observe the polarity.
  • kristapMA
    replied
    Re: Toshiba 49L621U
    https://www.badcaps.net/forum/attach...1&d=1524391578
    What DC Voltage do you have when measure right between the two legs of the two brown caps (100uF 160Vdc) laying on the side in that LED driver section that is marked with yellow box?
    replied
    Re: Toshiba 49L621U
    Standby
    1 - 0 - 16v2
    2 - 0 - 16v2
    3 - 0 - 16v2
    4 - 0 - gndp
    5 - 0 - gndp
    6 -0 - 16va
    7 - 0 -gnda
    8 - 0 - 16v2
    9 - 0 - gndp
    10 - 5 - 5v1
    11 - 0 - acd
    12 - 0 -pwon
    13 - 0 -blon
    14 - 5 - 5v1
    15 - 0 - dim
    POWER ON
    1 - all the way - 16v2
    2 - all the way - 16v2
    3 - all the way - 16v2
    4 - 0 -gndp
    5 - 0 - gndp
    6 - 0 - 16va
    7 - 0 - gnda
    8 - 0 - 16v2
    9 - 0 -gndp
    10 - 5 - 5v1
    11 - 3 acd
    12 - just under 4 -pwon
    13 - just under 4 - blon
    14 - 5 -5v1
    15 - 3 - dim
    When I tested 10 when the tv was on, the lights (LED) flickered on then off..
    is this what you were talking about?
    replied
    Re: Toshiba 49L621U
    Correction, one of them is 100uF 100V, another one is 100uF 160V.
    There should be Voltage on both of them when TV is turned on.
    replied
    Re: Toshiba 49L621U
  • CapLeaker
    replied
    Re: Toshiba 49L621U
    Originally posted by dick_barton
    The initial post indicated that there was audio but no backlights.
    The voltages given appear to support that all the DC voltages are up and running as well as Backlight On and Power On signals.
    Now trying to establish what the led voltages read on power up to see if there is a led(s) / led driver fault.
    Yeah, I know where you are going. I'd like to see the PSon and BLon state when that TV clonks out. Maybe there is a main board issue I'd like to rule out. Carry on Dick!
  • CapLeaker
    replied
    Re: Toshiba 49L621U
    you mean when its fully on? After the logo and it turns black?
    after the logo and it turns black
    09-06-2024, 05:27 AM
    09-06-2024, 05:59 AM
    09-06-2024, 05:33 AM
