sound, no picture after varying periods, Vestel 17IPS20, 17MB100
  • anyboby
    • Apr 2018
    • 10
    • Germania
    Hello Everyone!
    First off, I am new in this forum and was very impressed, by how much information I was already able to draw from it, so a big thank you already!
    I am currently trying to figure out a solution to a "sound, no picture" problem I am having with my Telefunken L48U300M4CW tv (48inch edge-lit LED TV) and I haven't been able to certainly determine the fault in the set based on my observations. Shortly after purchasing this tv it began turning off the screen after random, varying periods of times, while continuing the sound. A restart would always fix the problem, but I do feel like the periods of time, before the screen turns off are getting shorter. Movements of the LCD screen are still visible under Flashlight.
    So I wen't ahead and did various measurements (based on the information I drew from this forum) in the set with my meter, so here are the main findings:
    -all boards and hardware did look intact from a visual standpoint
    -the out-voltage to the LED Panel of the PSU rises to 106Volts upon turning on the TV and rests on levels between 101 and 105 Volts. When the backlights of the tv are turned off randomly, the Voltage rises to about 117Volts instantly and drops down to 80, where it remains, while the LED background lighting remains turned off. (interestingly the LED-out-voltage is on a lower level around 97Volts when watching via netflix)
    -I did measure the backlight on/off voltage on the PSU over the whole event and it remained on a constant 3.3 volts even when the backlights turned off
    -I disassembled the TV to get to the LEDs of the edge-lit panel and checked every single one, they all worked when testing them in diode-mode
    Now my current guess is, that it might be a main board problem, this is mainly based on MrReeceyburger123s comments (on this youtube video: https://www.youtube.com/watch?v=uPI1QBE0CxI&t=454s) where he says "Replace the mainboard if its turning off randomly".
    Now I also have seen a video where the uploader found capacitors to be responsible for similar symptoms.
    I'd be really thankful for any advice on how I should continue the troubleshooting to hopefully fixing this issue at some point!
    anybobya
  • vinceroger69
    • Mar 2012
    • 6714
    Re: sound, no picture after varying periods, Vestel 17IPS20, 17MB100
    maybe try what reece suggests at 8.30 mins in this video measuring the vcc voltage and see if it drops out when back light fails
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      While watching Netflix where you say the backlight voltage is set at a lower voltage 97V, does the backlight remain on longer?
      • anyboby
        • Apr 2018
        • 10
        • Germania
        Thanks for the quick responses!
        In fact, my impression was, that when watching on Netflix, the periods where the backlight remains on are even shorter. The same goes for watching via HDMI. Also once the backlight has been shut down, the issue seems to accumulate and reoccurs in much higher frequency, making the set shut off the backlight shortly after restarting the tv.
        I will definitely give this a try, just to make sure I got this right: If the mosfet vcc drops out when backlights are turned off, it is likely, that the LED-Controller-Chip is the culprit ?
        • vinceroger69
          • Mar 2012
          • 6714
          yes thats how i understand it from the video solder a wire on too the vcc pin on the mosfet (google part number for vcc pinout) reconnect all boards turn on tv look at voltage when backlights on and when failed.just dont let that wire you soldered touch anything as you dont want too short psu out and cause more damage.
          • CapLeaker
            Leaking Member
            • 8324
            Turn the back lights waaaay down and see if they stay on longer. If that is the case there may be a failing LED.
            • anyboby
              • Apr 2018
              • 10
              • Germania
              Hey, so I tested out this before getting to serious action on the psu and found this to be really working, the backlights stayed on cosiderably longer after turning down brightness and backlight from 50 to 0. That being said, is this already a clear indicator for the failure to be located along the LED strip?
              I made a quick internet search for the model number of the display (VES480QNES-3D-U02) and discovered a replacement part on here: https://www.vareza-elektronik.de/pro...oducts_id=4829
              I am not sure whether the stack repair as shown by MrReeceyBurger would work with an edge lit LED panel, especially when I haven't done anything like that before. Do you guys think the symptoms are decisive enough to purchase a replacement LED panel?
              Edit: If it is the LED Panel, I assume it is a heat- or general overpowering-issue (since they work for a while before shutting down), so would there be any possibility to test the LEDs for this specific failure with a multimeter ?
              • vinceroger69
                • Mar 2012
                • 6714
                did you try the test in post 2 i guess the driver ic could be failing under load?
                • CapLeaker
                  Leaking Member
                  • 8324
                  Well, I figured that is the case. LED's can fail like that and this turning down the back lights trick is a clear indicator to me that one or more back light LED's failing. Yes, best way is to replace the whole LED strip if you can. Reecey's trick works good too, but a new strip is the best. I've done all methods of repairing failed LED strips.
                  To answer your last question: No you can't do that with a DMM to find a failing LED like that. You have to power each LED or each LED strip up (I use a CV/CC variable lab power supply) and see which ones are failing.
                  Viel Spass bei der reperatur!
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    As these are edge strip leds you cant use the stacking method as far as i know? you maybe able to replace them though using a hot plate etc.
                    • anyboby
                      • Apr 2018
                      • 10
                      • Germania
                      I didn't do that test, as I preferred trying the "non-invasive" test with turning down the backlights first. I think I will give replacing the LED-Panel a try, since the seller seems to offer return service and guarantees for functioning LEDs. If that won't solve it, I guess I will have to do further measurements involving some soldering!
                      Dankeschoen
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        You got your answers.
                        1. Edge lit backlight LEDS cannot be repaired by the Stacking Method and cannot be properly tested with a DMM in Diode mode.
                        2. Though the individual beads can be replaced wit the Hot Plate procedure, replacing the entire strip is the BEST option, if you don't want to go in and repair them again.
                        3. Controller chip is a possible defect but I would rule that out for now as the voltages a good.
                        4. Finally. it is a LED Strip and NOT LED Panel as the Panel is the LCD screen glass and assembly.
                        • anyboby
                          • Apr 2018
                          • 10
                          • Germania
                          Ah, I got that mixed up, thanks for the hint
                          yup, and I'm very happy with the support on this board!
                          • brianbelfast
                            • Jun 2010
                            • 29
                            • Northern Ireland
                            Hi. Seven months later I know, but just wanted to add a note. I just had a Panasonic TX55CX400B with the same symptoms. It would run happily for hours on Standard definition channels from it's own tuner. As soon as you try to display HD or 4K the backlight would go out. Restarting the set would bring it back on. Processor trouble I guess. BL on signal was disappearing. I tried a quick reflow just for fun but to no avail. Replacement 17MB100 did the trick.
                            • psdavid65
                              Toshiba 40L1333DEV Vestel 17IPS20
                              by psdavid65
                              Quick Question Please.
                              Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                              All other components on this vestel board have valid readings except for this U202 IC.
                              09-21-2023, 12:29 PM
                            • Jaime Morillo
                              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                              by Jaime Morillo
                              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                              The TV was stuck on the logo and I couldn't access the update menu.
                              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                              The image result was good, but the image is inverted.
                              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                              08-18-2025, 11:38 AM
                            • Ruptor
                              Hitachi 55" TV dead after 18 months (Vestel 17MB100)
                              by Ruptor
                              I couldn't find any other thread that matches my TV problem but have been told it is a common fault. The fault is a flashing LED as if it is in upgrade mode that happens after a few seconds and stays forever. I can't remember all the tricks that have been tried like holding the select button when powering on but nothing worked. The shop sent me a flash drive to plug in a USB port but that did nothing either and they said it was dead which is disgusting for a piece of solid state electronics. I took the back off eventually after removing 34 screws to check for blown caps but everything looks new...
                              09-27-2021, 10:19 AM
                            • France_53
                              Vestel tv, how to flip the image?
                              by France_53
                              Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                              05-12-2024, 05:22 AM
                            • ray14324
                              Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                              by ray14324
                              Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                              The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                              Reading into this symptom the general consensus was that...
                              08-31-2021, 07:55 AM
