LC-52LE830U TVwith a (2 -5) error
  • speter
    Been around the
    • 77
    I have 11.8- 11.9 v at pin 1&2 and 11.9 at the IC switch, I have tried disconnecting the TCON from the LCD, and nothing changes, The backlight will not come on.
    Is there a way to force the backlight on? The TV was struck with a remote, but I can't see any damage. I have another power board with a standby power problem, I saw a thread on it's repair,I may use this one to try to fix it. I am not sure which is the better way to go.If I can get the back lit, I could see if the LCD is damaged.I tries a bright light at many angles and I can't see any cracks.
    I followed almost all of the suggestions from this thread.
    https://www.badcaps.net/forum/showthread.php?t=45671
    Goshen NY, USA
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • Scarfycake
    ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
    by Scarfycake
    I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
    05-21-2024, 08:16 AM
  • esben72
    Asus RTX 2070 Dual 8G - Need Capacitor - Where to find?
    by esben72
    TL;DR at bottom
    **Picture called Overview points out the cap in question***
    I have this RTX 2070 - It boots into bios but smells really burnt, so I opened it up I and saw the culprit:
    An SMD component with "100 C85" written on it.
    I want to find a replacement, and put it in to see if that fixes the card,
    but I have no experience in finding electronic components,
    and I dont even really know what a capacitor does in detail.
    Can some one help me, I have no real knowledge of electronics,
    but I have...
    02-24-2022, 12:54 PM
  • jimmyboy111
    Repair Log - TCL ROKU 65S4 BACKLIGHT DEAD
    by jimmyboy111
    Hopefully I can save someone some time or maybe they can avoid fixing these garbage epoxied TV sets
    .. stripping down was a pain .. tons of screws all along bezel edge .. the top of the glass LCD panel is glued to the casing (for a reason)
    .. all in all took around 4-6 hours to repair teardown .. swap .. reassemble .. current adjustment and then burn in and extra evening
    .. single blown backlight led top left row .. 3030 5.5v (6v) .. I had some in stock from another set
    .. swapping LED no problem .. one bad led .. the solder pad under this LED is normal .. no...
    02-01-2022, 11:33 PM
  • goodpsusearch
    Got 4 LG L222WS 22" for free - psu recap
    by goodpsusearch
    Got 4 CCFL 16/10 monitors for free.
    The resolution is almost Full HD (1680x1050)
    VGA Input only is a bummer though.
    Uses cheap TN panel with terrible viewing angles.
    Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
    All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
    01-15-2022, 05:36 PM
