Samsung UN40EH5000FXZA UF04 Service settings
  • SolderMaster
    • Dec 2013
    • 53
    Replaced a main in this set and I'm not quite sure what the settings in the service menu need to be.
    When powering on, it gives the message to set the Local, Type, and Front Color.
    I also notice while in service mode, the failures in the attached photos.
    Hopefully someone can tell me what the settings should be.
    I've looked online and couldn't find much about the actual settings.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UN40EH5000FXZA UF04 Service settings
    Can you do a firmware update to resolve the problem?
    http://www.samsung.com/ca/support/model/UN40EH5000FXZC
      • 12330
      • U.S.
      Did you try factory reset?
      • SolderMaster
        • Dec 2013
        • 53
        Firmware is the same as what was downloaded from the Samsung site.
        Yes, tried factory reset. Was able to set language, time zone, etc.
        When hooking up a video source, Blu-Ray player, it will show the Blu-Ray symbol as the player boots up, then the screen shuts down. Not off, but the backlights go out and nothing appears on screen. EDID and HDCP both show FAIL after factory reset.
        Also, forgot to mention, replaced all three LED strips. Shopjimmy.
          • 12330
          • U.S.
          Sometimes the reset don't take on first try.
            • 12330
            • U.S.
            n/a
              • 12330
              • U.S.
              Does tv work right when hooked up to antenna or cable?
              • SolderMaster
                • Dec 2013
                • 53
                Yes...sorta.
                We don't have a digital tuner box in the basement so I hooked up an Atari... picture is fine through the coax connector.
                  • 12330
                  • U.S.
                  Post #2 might be helpful, seems like he went into EDID sub menu and turned it on. http://www.avsforum.com/forum/166-lc...menu-work.html
                    • 12330
                    • U.S.
                    Most articles say always reapply firmware whenever mainboard change.
                      • 12330
                      • U.S.
                      Always be careful when changing things in service menu, make note of original settings, could also be a bad mainboard as in hardware failure instead of a software issue.
                        • 12330
                        • U.S.
                        n/a
                        • SolderMaster
                          • Dec 2013
                          • 53
                          Can you force an overwrite somehow? After the set scans for the USB, it says Same Version, Please check and try again.
                            • 12330
                            • U.S.
                              • 12330
                              • U.S.
                              I think this is what you need to follow, look at the part about mainboard replace and reset,
                              make note of your settings before so if you have to you can put them back in, read it carefully go step by step.
                              https://electronicshelponline.blogsp...eshooting.html
                                • 12330
                                • U.S.
                                Any update.
                                  • 12330
                                  • U.S.
                                  No followup/feedback, going to ass u me that you fixed it.
                                  • SolderMaster
                                    • Dec 2013
                                    • 53
                                    Sorry, got busy with my day job.
                                    I removed the back to make sure this was the set I replaced the main on...and it isn't. (I had 4 sets apart at once and confused the main repair)
                                    This set I replaced the EEPROM on. This set also had the backlights replaced. I will pick up a whole main board and throw it in there to see if that gets her goin'.
                                    Again, sorry for the delay in responding. I rewind electric motors by day and we got pretty busy.
                                    I really appreciate your responces. Thank you all!
                                    • SolderMaster
                                      • Dec 2013
                                      • 53
                                      New main did the trick. Checked the service menu and both EDID and HDCP had SUCCESS after it. Did a factory reset and all is well again.
                                      Thank you all for your help!!
                                        • 12330
                                        • U.S.
                                        Thanks for feedback, so looks like the service menu settings didn't help with the edid and hdcp giving failure report, needed mainboard for the fix, thought that mainboard was buggered up, glad you got it sorted.
                                        • GeckoGreen
                                          Samsung service bulletin: need firmware file for PN63C550 TV
                                          by GeckoGreen
                                          I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                                          You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                                          The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                                          Will you please help me get the [2D63]LOGIC.bin file for my TV?
                                          05-17-2025, 02:47 PM
                                        • Daniel Valdez
                                          Samsung UN70RU7100K halfway bricked after messing with service menu
                                          by Daniel Valdez
                                          Dear All,
                                          FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
                                          12-06-2024, 06:56 PM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
