Samsung UE37D5720 permanent reboot, 3.3V ok but MCU hangs up
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Samsung UE37D5720
    Chassis: U66A
    Main board: BN94-05068V
    Power Supply: BN44-00422A
    Hello all, this TV set is lighting on and permanently rebooting after the Samsung logo, the STB 5V coming from the power supply is correct, the mainboard is producing the 3.3V at the regulator IC1203 , this one is correct as well and it is the only permanent voltage i could find on this main-board.
    When rebooting all other voltages are shutting down and when controlling the oscillation at the quartz of the micro-controller i could see with the oscilloscope that it disappears when rebooting, that means the MCU is hanging up.
    I could not find any schematics for this mainboard to find the reset pin and power input of the MCU and i can't peal off the solid square heat-sink from the MCU to see the number of it.
    If you have any ideas thanks a lot again.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung UE37D5720 permanent reboot, 3.3V ok but MCU hangs up
    You can try a reset of the EEPROM by putting a wire between RESET and SDA.
    This video will give a pointer although it's in German there are English subs. https://www.youtube.com/watch?v=DDzOSdfA41s
    I believe they also suffer from corrupted/failed NAND that needs replacing.
    • yoritomo
      • Sep 2012
      • 155
      • Belgium
      Thank you very much for this link, i tried many time that hard reset, doing exactly as he said in the video but no success. Very useful tip for a next issue anyway.
      From the main-board i can hear a high pitch hissing when on, it perhaps means it has a short somewhere ?
      What are the main powers absolutely necessary for the MCU to work properly ? I would expect the main 3.3V , 1.5V ram power and the core 1.2V right ? if any is missing the MCU is down, am i right ?
      • diif
        • Feb 2014
        • 6978
        • England
        It depends on the noise, it could just be coil whine. Hissing could also be a capacitor venting (but I think doubtful)
        Are there any markings next to the connector from the power supply to main board ?
        They should be marked with voltages.
        I believe the D series Samsungs and possibly others have the EEPROM load information from the NAND. If the NAND becomes corrupted then this isn't possible and results in a boot loop.
        • yoritomo
          • Sep 2012
          • 155
          • Belgium
          Hello i finally solved the problem by a surprising way.
          I froze the nand with a spray, then the tv could start normally, long time enough to enter in the service menu and to apply the factory reset, i let it run for a long test period, cold or warm, it still be always working now since yesterday.
          This is not a BGA nand chip, just a normal one, then i don't expect any fails after from it, anyway i don't neglect that another factor could cause the rom corruption, then let's see after a while.
          Anyway i will set the post as Solved.
            09-07-2024, 05:50 AM
          • plytek
            Samsung QE50Q60TA rebooting
            by plytek
            Hi all.
            I'm trying to fix my Samsung QE50Q60TA TV.
            IT's rebooting every few seconds.
            I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
            Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
            Can anyone suggest what I can test and do to get it working again please?...
            02-08-2025, 06:02 AM
          • unimatrix93
            SAMSUNG UE55TU7002KXXH rebooting
            by unimatrix93
            Hello everyone, I'm working on a Samsung TV that constantly rebooting.
            MB/PSU unit: BN9654185QE
            It loads up to the main menu then as soon as the backlight goes brighter it reboots.
            First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
            Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
            Also I have to note, that the MB/PSU combo gives out a very noticible...
            04-07-2025, 09:49 AM
            09-06-2024, 11:40 PM
