Need help with samsung pd550 service menu settings
  • bapiraju
    • India
    Hello Every one,
    I own a Samsung pd550 plasma display and recently it had an issue where the HDMI ports stopped working. I read somewhere that a Hard reset from service menu might help, which I tried and did not help. Also unfortunately while I was at it I accidentally messed up my service menu settings and now the picture I get is Purple/Magenta in color. I observed that the color hue settings for Green is set to zero and I cannot increase it.
    Can some one please help me with correct settings for the service menu for this TV to overcome this magenta color problem and any pointers for resolving the HDMI port issue.
    I tried reaching out to Samsung support, but the technician who came over wasn't much help. He was insisting that the panel was faulty and needed to be replaced, I pointed out that the colors in the menus seem fine and only picture from video sources are having issues with color. I also informed him that I have accidentally messed up the settings but he is adamant that the issue is either with the panel or the mother board and replacing either would be cost prohibitive for me.
    Appreciate any and all help in this regard, Thanks.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Need help with samsung pd550 service menu settings
    Your HDMI ports quit working due to the fact that you have a sub codec processor that for most likely failed not sending the handshake data to the main processor. This processor is most likely a silicon image or Samsung proprietary.
    As for the service menu check to see if your LVDS input is set to JEIDA. Also mow many bits? 8, 10? You could try changing those settings and if it doesn't work put it back to the original value. None the less if you have a codec processor failure if you don't know how to pull that processor and replace it you're looking at a replacement main board anyway.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Daniel Valdez
      Samsung UN70RU7100K halfway bricked after messing with service menu
      by Daniel Valdez
      Dear All,
      FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
      12-06-2024, 06:56 PM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • GeckoGreen
      Samsung service bulletin: need firmware file for PN63C550 TV
      by GeckoGreen
      I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
      You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
      The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
      Will you please help me get the [2D63]LOGIC.bin file for my TV?
      05-17-2025, 02:47 PM
    • tusiime
      How to access Vizio m652i-b2 service menu
      by tusiime
      The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
      So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
      Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
      09-15-2023, 09:57 AM
