Toshiba 27" TV Random Channel 1
  • Krankshaft
    • Jan 2007
    • 2328
    Well this TV is acting up again it has been performing great after the 100uf cap replacement on the vertical IC.
    Lately it has been doing something really strange if I turn the TV off for an extended period and turn it back on the TV won't memorize the last channel it was on and will tune to channel 1.
    Not only that it will sometimes randomly tune to channel 1 while the TV is operating. Not very often but it has happened at least 3 times.
    I understand why it would do it with the TV off if the last channel is not being saved into the EPROM but while the TV is on???
    Anyone ever dealt with something like this before?
  • Toasty
    • Jul 2007
    • 4171
    Re: Toshiba 27" TV Random Channel 1
    I have seen this on my 25" Hitachi. Does it have an switch for CATV1/CATV2/ANT input select? If it does, check it for dirt. Weird, but that's the problem mine has. Random jump to CH4. Drove me nuts at first, thought the remote had lost its mind.
    veritas odium parit
    • Wizard
      • Mar 2008
      • 2296
      This toshiba tv, have notorious solder problem. Go over everything: big resistors, diodes and power transformers and coils. Then replace any capacitors that is looking bad with ESR meter. (required!)
      Cheers, Wizard
      • Krankshaft
        • Jan 2007
        • 2328
        You were spot on Wizard the caps over the chroma IC were toasted.
        I think I must have replaced at least 15 small value (under 10uf) lytics. They were mostly Rubycon but underrated temperature wise they were 85Cs.
        A light board darkening on the component side of the chroma IC signaled the heat to me.
        I then went over the entire board with my fluorescent magnifier and touched up I don't know how many joints.
        No random changes yet but I'll give it a few days.
        I think I found the source of my intermittant loud HV whine too. A 22 uf 250V cap that supplies the color output transistors through an inductor. It's ESR was around 65 ohms I had to leave it in for the time being until I can order it from Newark though.
        I have had inductors and transformers sing from bad caps before and I'm sure this time is no different.
        That value is too obscure to have in my stock.
        All the caps were Rubycon YK series there were some others I replaced with a big R on them but they were in the minority.
        Also this TV was manufactured by Orion in Taiwan (right again) it said so right on a label on the chassis and on the tube.
        The ESR meter was a must for this one I would be nowhere without it.
        It seems like in low heat areas the 85Cs hold up just fine but in the hotter ones (like over SMT ICs and near heatsinks) they die pretty quickly.
        • Wizard
          • Mar 2008
          • 2296
          Then it is not toshiba. Toshiba is yellow label for toshiba chassis.
          Cheers, Wizard
          • Krankshaft
            • Jan 2007
            • 2328
            Yikes I have another 32" Toshiba (i.e. Orion here too) it has a white label so I'll assume Orion.
            If I knew this back in 03 I wouldn't have purchased either of them.
            Not a single problem out of it yet though.
            It's the same age as the 27" manufactured in 2003 so I guess they put 105C caps in it since it's still performing flawlessly.
            • Wizard
              • Mar 2008
              • 2296
              Typical.
              Eventually, just get good TV. Avoid generic brands.
              Cheers, Wizard
                09-06-2024, 05:27 AM
              • dicky96
                Hitachi V19B01922 Channel Tune problem
                by dicky96
                Hi Guys
                I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                He also has an LG TV, so three screens in the bar
                I installed three Satlink ST-6503 DVB-T Modulators
                This model https://www.aliexpress.com/item/32916553905.html
                These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                02-09-2023, 09:20 AM
                09-06-2024, 05:59 AM
