Replacing caps for Samsung DLP HLT5675S
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    From a DLP power board. 200V 470uf, ripple is 2230mArms
    I can't seem to find anything close enough. Close enough decent quality I found was UCC EK, at 1770mArms
    diameter 25
  • Stefan Payne
    • 1267
    Re: Replacement for CapXon LP
    85°C caps allow higher current.
    look for those.
    if you can't find any ask manufacturer for advice.
    Because in some cases some 105°C caps can endure higher current but must be treated as a 85°C one in that case.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      might have found one
      https://cdn.badcaps-static.com/pdfs/...8344553467.pdf
      not sure about the leakage current though
      • Stefan Payne
        • 1267
        I've found something cheaper:
        https://www.mouser.de/ProductDetail/...mLf3dAMEETU%3d
        https://www.mouser.de/ProductDetail/...FpJyP7yEJtA%3d
        The others I've found don't seem to be available.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5045
          • US
          zero available. and the ripple is at most 1970mArms. The one i'm replacing with is 2.2Arms
          • madscientist750
            Replacing electrolytic caps by solid caps on old motherboards
            by madscientist750
            I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
            I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
            I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
            10-19-2025, 06:10 AM
            09-07-2024, 05:50 AM
          • Noodneek
            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
            by Noodneek
            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
            08-30-2024, 12:52 PM
            09-06-2024, 11:40 PM
