Sony KDL-52V4100 with almost white image
  • Yanleb
    • May 2017
    • 102
    I just want to share the fix on my Sony KDL-52V4100 LCD TV set with a bad T-Con board.
    The problem was an almost white image, typical of a bad chroma chip. After verification, I effectively found on the T-Con board that the chroma chip was outputting only half of the 18 chroma reference voltages. Under the FPC_LEFT ribbon connector, VGMA1-VGMA8 test points were fine producing different voltages in descendant values from about 20 volts to about 7 volts, but VGMA9-VGMA18 were all at zero volt.
    Since the service manual for this board is not available, I found that the chroma chip was IC321. It is a ISL240007IRZ made by Intersil (now Renesas). It is a programmable 14-Channel x 2 Bank, 8-bit TFT-LCD VREF Generator. Each bank has its own I2C serial interface. Sadly, the detailed spec sheet for this chip is not available. So no pinout.
    I was about to order a replacement chip when I remarked 4 test points labeled VREFL_L, VREFL_H, VREF_U_L and VREFU_H. I figured out that they were the two I2C serial interface to program each bank of the chroma chip. Now, if one of the two I2C serial interface was missing the programming signal, it would explain why half of the reference voltages were missing.
    Bingo! I found RG18 connected to REFU_L that was open. It was a 0603 resistor of 6.8K ohm (marked 682). I didn't have a replacement resistor on hand, but in my scrap pile of boards I found a 0804 6.8K ohm resistor that was an almost perfect replacement. After soldering it in place, connecting back the T-Con board and powering up the TV set it was fixed. Perfect image.
    The fix is applicable to the following Sony models that share the same TCON board :
    KDL-52S4100
    KDL-52S5100
    KDL-52V4100
    KDL-52V5100
    It should also apply to a similar T-Con board having the same THF9301 main chip, like the FHD60C4LV1.1 and the 320HAC2LV0.0.
    I hope it will help someone.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL-52V4100 with almost white image
    Great work! I have seen a lot of these boards with gamma problems I've dealt with a few myself. I threw one out because I couldn't figure out why have the voltages were missing.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Excellent repair.
      • fabstagiaire
        • Frabce
        Your post was of great help to repair a Samsung TV (LE32A568) equipped with similar T-CON : 320HAC2LV0.0 LJ94-02296C / BN81-01689A
        Sometimes it was working sometimes it was white...
        And quess what: same bad voltages... and same RG18 broken resistor. The only difference is the value: "272" meaning 2.7k , and I was measuring 19k !
        I replaced it with another 2.7k ... and the TV is back to life !
        Thank you very much !!!
        • domix
          Sony KD - 65XF9005 - No image, sound OK
          by domix
          at tv KD - 65XF9005 i have a problem.
          Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
          is this a common problem for this tv?
          i attached pictures of inside. Supply board looks okey, no blowed caps....
          07-21-2025, 06:37 AM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
        • Dreamcazman
          Sony KV-XJ29M31 CRT TV - Very dim image on turn on
          by Dreamcazman
          Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
          Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
          Once it's running properly, it keeps...
          02-28-2022, 07:47 PM
        • x_orange90_x
          Sony KD-60X690E 6 Blinks, no image
          by x_orange90_x
          I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
          I...
          12-10-2024, 09:10 PM
        • Cheesesteak
          Sony XBR-55A8G 4K OLED image ghosting/jumping around
          by Cheesesteak
          Hello All,
          Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
          I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
          I saw some people had success...
          04-18-2022, 04:35 PM
